i need a new laptop... and need to plug my Aptus II 7 ( DM33 ) via FW800 in the field...
I have two options :
- buying a macbook Pro 2012 non retina... but to have a good VRAM (only 1g.. ), then you have to go with the 15" 2.6Mhtz... it still cost around 1000 euros in second hand, and you have to buy an SSD, and probably some RAM...
let say 1400 euros if the battery still ok... and no warranty...
- buying a new Macbook Touchbar 15" and adding the MAX VRAM... 4Go... it will coast 3300 euros but new...
the trouble is that there's no FW800 only TB3 !
so i need :
FW800 HUB powered
FW800 to Thunderbolt 2 adapter
Thunderbolt 2 to Thunderbolt 3 (USB-C) adapter
so, if i want to use the set up in the field, i will need a battery to powered the HUB ( and thru it the DB ! )
I know the discontinued and expensive quantum can do the trick...
but can i used one of these ?
https://www.amazon.fr/gp/product/B00YP823NA/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A3KPCAN4ISC0PS
https://www.amazon.fr/Litionite®-Tanker-50000mAh-Aluminium-Batterie/dp/B01LZXPMXM/ref=cm_cr_arp_d_product_top?ie=UTF8
https://www.amazon.fr/XT-20000QC2-PowerBank-batterie-moderne-20400mAh/dp/B01M9BGFJM/ref=sr_1_1?ie=UTF8&qid=1491343067&sr=8-1&keywords=B01M9BGFJM
my hub is an Unibrain :
DC Power connector: Walkman-type 2.0 mm DC, Power Input Range: DC 8V~30V, max. 1.35A.
Power Consumption (at 12V DC): 1.5W max.
FireRepeater-800 Pro, 5 ports | UniBrain
so i need :
FW800 HUB powered
