I have a cambo WRS1200 with the following schneider XL lenses; 24mm, 35mm and 47mm. I will be buying a medium format digital back in the next 1-2 months. Looking for advice to which medium format back would work best with the lenses I have, an older IQ160 or the newer IQ 150/250
Cambo WRS1200 is a very good camera indeed.
I am curious about your lens choices though... the SK24 lens does not have an image circle large enough to cover any 54x40 sensor. I don't have first hand experience with it but based on what I have read, it is not going to be that great with IQ150/250 either. Did you buy SK24 for a particular reason?
I think SK35 has a lot of current and prior owners here and they'll probably tell you its characteristics, but it is probably the best performer out of the three lenses you've purchased. I've seen many excellent images in the
Technical Camera Images thread, captured with SK35. No distortion and excellent image quality.
Both SK35 and SK47 will behave much better with a IQ160/Credo60 than with IQ150/Credo50. However, the 50MP backs offer live view which CCD backs do not (well they do, but it is not very good). Although, Capture One 10's improved LCC routine handles color cast in a much better way - making the 50MP CMOS DBs quite viable too.
Your SK24 is the odd ball out, and I am not quite sure how you are going to put it to work. If you have the possibility to return the SK24 it might be advisable.
Your SK35 would benefit from a center filter too. So, if you do not already have it, you can start looking for a pre-owned CF now, since SK do not make these (lenses or CFs) any more.
