h6d firmware tech cam finally
Boinger
So just thought I would put this out there
if you use pinhole mode it works like an electronic shutter but with a max shutter speed of 1/8th s
masud
Just so I don't misunderstand, by "max shutter speed" do you mean that the longest is 1/8 sec or the shortest is 1/8 sec?
Thanks much!
Boinger
Thanks much!
Shortest is 1/8th sec.
The longest is quite far I didn't explore a maximum in my body.
bernardl
How is the H6D powered on a tech camera. Is there a external power pack?
Paul Caldwell
Yes Paul.
Please refer to pages 164-168 of the latest manual linked below. Power is provided through the DC input socket from an external power bank. One pack from XTPower is confirmed to have been tested but others should work also.
There are 2 modes:
- Flash sync mode for lenses equipped with a flash sync port (the lens controls speed and aperture)
- pinhole mode for lenses not equipped with one (the back controls the shutter speed and triggers the capture on screen)
http://static.hasselblad.com/2016/04/H6D-User-Manual-v1.4-170418.pdf
Sounds like a workable solution to me. I am considering to 3Dprint a soft plastic bracket that would enable to carry the battery with the back, should be painless.
Bernard
Boinger
I am currently Using the XTPower Mp-32000
Much larger capacity then the one listed in Hasselblad manual it seems to work fine as it is the same company I use that in my studio environment but I have ordered the Hasselblad recommended power pack.
As soon as you plug the cable in it automatically turns on.
I just velcro'd the power pack to my studio stand and will probably hang it on my tripod just for simplicity.
