I have an Aptus II10 back. I dont actually have it in my hands yet but it will soon be inbound to me. So getting ready for it.
I want to understand the tethering operation on this back.
I understand that there are some issues tethering the Aptus II series of backs. Specifically that the battery blocks the firewire port. Because of this if one wants to tether then the back has to be powered via the firewire port.
From what i understand there few laptops and even less tablets that can provide power over firewire. I believe this is because most laptops that even had firewire were 4 pin firewire ports and a 6 pin firewire port is required to provide power to a peripheral device over the firewire bus and that the power is supplied on pins 5/6.
I think i have all that right.
From research i have done it seems firewire voltage over pins 5/6 can be anything between 7 and 40v.
How much voltage is required to drive a back via fw ?
I have found a touchscreen tablet running WIN 7 and that has a core i7, 8GB's RAM and a SATA SSD onboard. It has a 6 pin fw port and tech support tell me it outputs 19v on the firewire port to drive peripherals.
If these specs are actual (having that checked by tech support to be 100% sure but it looks to be the case) will this tablet be able to run the II10 in tether mode?
Which is the best software to run in tether mode on that back? Ver of that software given WIN 7 OS.
Thanks for any info anyone can provide.
