XF Fine Tune
aztwang
Is there a menu option to set up a button on the XF body to open up fine tune adjustment rather than
going thru 4-5 button sequence to get to that adjustment?
Cheers
Don
ejpeiker
Cheers
Don
I am assuming you are referring to what Phase One calls Focus Trim? If so, the fastest way to it is to hit the top panel silver button closest to you on the XF, which will bring up a screen on the top LCD that has Capture set-up highlighted, rotate the dial nearest the the power button one click and then scroll down to Focus Trim - from that point on, as long as you don't wait too long, every time you hit the silver button on the XF closest to you, it will go directly to the Focus Trim selection. I do not believe you can assign that function to a button.
