Jon Warwick
My questions probably morph over the LF camera / MF / etc forums, but i will try here given it potentially seems the most appropriate as a more modern piece of kit.
I am interested in the Arca Universalis due to its apparently high flexibility as a precision camera body that is suitable for both digital backs (either MF or mirrorless 35mm) + 4x5 film.
Perhaps unusually (if not more traditionally!), I'm angling towards the 4x5 format of the Arca Universalis as the initial set-up.
Has anyone used this set-up across either mirrorless / MF / 4x5? .....it seems super light for what is claiming to be all-metal and high precision, which makes it seem very attractive indeed for travel.
My question is .....how stable is it (e.g., are the front and rear standards 100% precisely aligned and very rock solid, or do they flex if you push them?....as a background in 4x5, I've say a Linhof Technika was pretty rock solid, but you could flex an Ebony's standards).
When i introduce a digital back, is the rigidity / precision / alignment also there for multi-stitching a mirrorless (I have a Leica Monochrom) and / or MF back (likely in the 50-80mp range one day)?
In addition, which other options exist that you'd suggest could provide multi-use (digital and film) flexibility?
Thanks!
Thanks!
