Yes, that is the way to get one, I recall seeing it on the Capture Integration website.Standard item in the UK Hasselblad Price List:
3043410 Hasselblad High Performance Case £265.00 ex VAT (sales tax)
Any Hasselblad dealer can order or may have stock.
Wow, you are so right! Thanks, Ken!I bet Custom Foam Case Inserts - MyCaseBuilder.com would work
GetDPI thread here: https://www.getdpi.com/forum/medium...ase-foam-design.html?highlight=phase+foam+cut
Not the right kinda foam and as of three months ago no hasselblad templatesI bet www.mycasebuilder.com would work
Thanks, Steve,My Case builder site gives the option of polyethylene or polyurethane.
They say Polyethylene is: good for objects that can absorb a modest amount of shock without being damaged (example: electric drill).
Polyethylene makes quality foams, though expensive. It is rougher, but I don't think it will scratch equipment. So, if your case gets dropped, the lenses are being dropped too, but not as hard.
They say Polyurethane is:
* Good for more delicate objects that may break on modest impact (example: crystal stemware).
* Good for irregularly-shaped objects (example: digital SLR camera).
I have had my Pelican case with the pick and pluck foam in it for about 10 years. It is still intact and does not get onto the equipment.
Polyurethane foam is notorious for turning into goo and / or powder after a while, also apparently releasing Volatile organic compounds (VOC's) in the process. It can completely destroy the items, such as expensive optics, it was originally intended to protect. And it can disintegrate rather suddenly.
I've had the same experience discussed above with the gray open-cell foam used in old cases - it deteriorates and turns to sticky gritty dust after 10 or 15 years - a mess to get off things.
Ozone is pretty much everywhere and it is a very potent oxidizer. It is generated in quite large quantities in sunny cities and forms an oxidizing smog. In areas of high ozone concentration, such as Phoenix, Los Angeles and Vancouver, foam stuff dies quickly. If you live in a city that has low sunshine hours, the foam will last for quite a while.
I think you are good with Polyurethane as long as you check it, and replace it every 10 years or so.
--Steve.
Following up on the custom case template... does anyone have a picture they would like to share shwing their hard case with camera/lens/batteries, etc. in place? What does one do with battery charger/cables/misc. items?Thanks, Steve,
It appears that polyurethane is the way to go... with a replacement every five years. I am good with that!
Just wondering if you have an update for this thread. After going through everything I could find about a custom case alternative, I have decided that this case is the one I would prefer for my use. It is actually cheaper than a Billingham Hadley Pro Large bag!Has anyone ever seen this item? Is it for sale somewhere? Thanks.
