Interesting question on the 1 vs 2 screen usage. In general, I prefer to do my photography on a single screen (with Lightroom) dedicated to the task. I use macOS 'workspaces' to be able to quickly switch to other things at breaks in my workflow.
This is likely because I generally spend less than a minute or so rendering any individual photo. I try to get everything right to the greatest extent possible in-camera and have built up a nice library of processing presets that speed the work along such that I spend very little time doing just finish tweaks. I've forgotten how to use Photoshop at this point ... other supplementary editors are simpler and faster.
The situations when I need more screen space are when I'm assembling a book or a movie. Then I have the need to look at a lot of different things simultaneously and I'll add a second screen to my system for that, if one is available. It makes the best work environment for me if both screens are identical and calibrated to display identically in those situations, so the notion of mixing a high-end screen with one characteristic and 'standard' grade screen is less optimal.
My hardware is arranged such that I can plug in displays, cpus, external drives and devices at will. Just which CPU I'm using is mostly irrelevant in absolute terms, as long as it has the memory and performance I need. When it becomes significant is when I plug in the laptop because I've been doing some tethered shooting vs using my mini (the normal case) or Pro (mostly for editing motion work).
Given that 99% of what I work on is 24Mpixel FF format images, my mid-2012 mini with the top line processor, 16G RAM, and a 1T SSD is still fast enough to satisfy my needs for still photography. If I were working with 100Mpixel images all the time, it would be strained a bit to give me the responsive editing workflow I like and I'd upgrade it. If the upgrade today happened to be an iMac Pro, well, so be it... then I'd have my second monitor solution at hand a little more readily.
