CAMBOUSA
Hello everyone,
I figured I would start a new thread here so as not to cloud up the Firmware announcement thread. If anyone has any questions, I'd be happy to answer them.
Please be aware that the images I am about to share are for working prototype units, and some design changes/finish changes may occur before final release.
CA-XCD
https://www.cambo.com/en/actus-mini/cambo-actus-xcd-view-camera/ca-xcd/
From Cambo:
Based on the knowledge used in our other Canon lens adapters, Cambo has now created an adapter to enable the use of Canon lenses on the Hasselblad-X1D camera.This adapter is mounted directly to the X1D camera bayonet and it controls the aperture of Canon lenses electronically, by similar controls as on the ACB-CA, WRE-CA and CA-GFX. Be aware that there is no further protocol to communicate with the X1D camera for setting aperture, auto focus or EXIF date from the lens.
It may be obvious that only Canon lenses that have a larger image circle, such as the T/S lenses, will have enough coverage for this sensor.
This combination makes it possible to use the Hasselblad X1D camera with a 17mm (and 24mm) focal length that covers the full format of the X1D 33x44mm sensor. Depending on the composition you may still be able to use the T/S movements on the lens unobstructed. More information will be released about compatibility with the newly announced Canon TS/E Lenses as they are available for testing, however at this time it can be assumed that the image circles will be of an acceptable size.
As there is no mechanical shutter in this setup, there are limitations in use with certain light sources, exposure times and subjects, we refer to the information from Hasselblad about this.
Actus-XCD
From Cambo:
As a further development of the ACTUS-G product line for medium format mirrorless cameras, Cambo is now introducing the ACTUS-XCD to host the Hasselblad X1D camera body.
The ACTUS-G system was already available as ACTUS-GFX for the Fujifilm GFX series, now the bayonet holder can be supplied with the XCD bayonet from Hasselblad. The bayonet holder is interchangeable and include Cambo's convenient internal rotation between landscape and portrait position.
These products are available for pre-order now from all authorized Cambo dealers, and should begin shipping later this month. Pricing will be the same as the Actus-GFX and CA-GFX counterparts.
At this time I haven't been made aware of any upgrade kits from existing Actus units, but I can assume that these will come in time.
CA-XCD
From Cambo:
Actus-XCD
From Cambo:
