Hello All,
I am having some trouble syncing a newly purchased proiid body with my p65+. It does not seem to communicate with the digital back.
Once the DB is connected, the shutter release stops responding. The body works fine on its own (in M mode), it works ok with a film back. (again M mode) but once the digital interface comes into play and the back is "On" the camera stops responding.
You can release the shutter in the emergency mechanical mode when the back is on but no image is recorded - I doubt it would work that way anyway as the p65+ back needs the body to be powered on to recognize it anyway. Also, when I press the shutter a few times in succession - the shutter feels 'slack' as if you've forgotten to cock the shutter - it does occasionally fire (1 out of 10 times but not always) but, again, no image is recorded.
I think I've ticked all the boxes in terms of settings, batteries, checked the hx701 adapter with a multimeter (PCB is not damaged and connectors work fine i.e. the connector pins correspond to the PCB's layout) tried a different lens, downgraded to an older firmware on the DB - all to no avail.
My DB works absolutely fine on a PhaseOne DF, which uses an even more sophisticated digital interface but I've never had a chance to test it on another rzproiid. I already use the DB on a RZ pro II but it uses a sync cable so the interface is different.
The settings are Normal Latency mode with RZ67ProIID mode active. Does anything else come to mind?
Thanks in advance!
Thanks in advance!
