Much impressed with the new firmware, been testing this afternoon. But I don't understand why do you have to "press a button to call up the AF point". After configuring the touch screen control of the AF point, you only have to bring the camera to your eye and move the point to area of focus.I can now press a button on the X1D body to call up the AF point selection grid and use my finger on the left side of the touch screen to move the point selected while looking through the viewfinder. For me, this is much more efficient to use than a joystick on the right side of the camera body, as I hold the camera body with my right hand and use my right eye to look through the EVF. So much for no joystick!
To be frank, I am pleasantly surprised by the rapid pace at which Hasselblad is issuing firmware upgrades. It demonstrates a commitment to the X1D system that is reassuring. The list of missing items in the firmware is dwindling fast.
Good question. With the prior firmware, you couldn't move the AF point unless the grid was first called up. I had assumed that was still the case, so that's the way I tested it.Much impressed with the new firmware, been testing this afternoon. But I don't understand why do you have to "press a button to call up the AF point". After configuring the touch screen control of the AF point, you only have to bring the camera to your eye and move the point to area of focus.
Very kind of you. Thanks.By the way, I love your Tuscany portfolio.
Yes, that does seem like low hanging fruit. Just like exposure bracketing. Strange. You know who to email about it!!!No change to auto ISO behaviour. I’m starting to think there’s some reason they can’t do it, given what low hanging fruit it should be and what a poor system it currently has...
This will only work with full aperture, e.g. f/3.2 with the 90mm. You can see the difference clearly if you look in the lens with DOF preview activated (also shown in the manual page 107). Maybe we have a f/2.8 now.I just did the update for the camera and for the lenses. I tested out the bokeh with the 90mm XCD but I'm still seeing octagonal....anyone else? (I tried with "normal" shutter and e-shutter)
Thanks for pointing that out! Apparently this was a case of "I should've read the manual"....I didn't realize there was a menu setting you had to change. Anyway, set to full, no more octagonal @ 3.2 with the 90mm :clap:This will only work with full aperture, e.g. f/3.2 with the 90mm. You can see the difference clearly if you look in the lens with DOF preview activated (also shown in the manual page 107). Maybe we have a f/2.8 know.
The octagonal bokeh is most accentuated with the 90mm although it is also visible with the other two lenses. As far as I can see, the firmware update (full round) gives perfectly round shapes at least in the centre.
You are right. No need to call up the grid anymore. Just swipe away!Much impressed with the new firmware, been testing this afternoon. But I don't understand why do you have to "press a button to call up the AF point". After configuring the touch screen control of the AF point, you only have to bring the camera to your eye and move the point to area of focus.
My Panasonic GM5 works this way, I find joysticks clumsy in comparison.Really an ingenious move from Hasselblad !!
I have not seen this kind of implementation via EVF with other camera brands (maybe somebody knows).
The ergonomics are all wrong when the joystick is on the right side of the camera body and the grip for the camera that you use to hold the camera is also on the right side. Why are the joysticks not on the left side of the body???My Panasonic GM5 works this way, I find joysticks clumsy in comparison.
I do not understand how you are holding the camera. In my case I use the left hand to hold the lens and handle focus and/or zoom, while using the right hand to hold onto the grip, one finger on shutter, thumb on joystick to move the focus point. Especially with wildlife photography, everything is being handled at the same time and with a heavy lens, you need to support it with the left hand. On tripod it is less of an issue what is where.The ergonomics are all wrong when the joystick is on the right side of the camera body and the grip for the camera that you use to hold the camera is also on the right side. Why are the joysticks not on the left side of the body???
