420 nits max for the Surface Go, according to some reviewers tests. Pretty decentSmallHD 5" on camera Focus Monitor - it has 600nits brightness, so you can see it really well on a sunny day. (many others fail in this respect). Connects to your miniHDMI port on the IQ3-100.
I find using the screen on the back unreliable - its too small and too dim.
Also use Surface Pro 4 when working tethered. They have a new one out - the 'Surface Go', which should do the job too, and is smaller and very affordable, but not sure of screen brightness. Couldn't find that figure anywhere online.
That should be plenty, even more so because you can decide where you hold it. And it's way more versatile than just a monitor even when used as a monitor with all the C1 features.420 nits max for the Surface Go, according to some reviewers tests. Pretty decent
