Don Libby
Why not have both?Maybe Graham is right----that Phase IQ3/4 Achromatic sure does make sense now :ROTFL:
Yes, it takes a while to work through all those tests and form a clear picture of what works well and where the limitations are. I can tell you that the 24 TSE works pretty well at 850, so that will be a good wide option. The periphery of the image circle gets a little soft and there is a diffuse hot spot starting around f5.6, but it is easily correctable in post. The 17 TSE doesn't have any hot spot issues, but it is a little softer at the edges than the 24. However, the 17 is a great option when you need to go really wide. Also, for future reference, the 50 TSE is an excellent performer in IR across the entire image circle and has no hot spot issues.Thanks Josh. This was my thinking as well. It's the IR that causes problems, so the 32-64 should be fine with the Hot Mirror, but definitely will need to test it with all the filters. I'd place bets that if the AR option for the GFX was available from Kolari, the difficulties with the hot spots might be a non-issue. The AR option is available for other cameras, and it is a worthwhile addition.
I have the Canon 24mm TSE II and adapter that I can use on the wide end. The GF 45mm will probably be a good standard wide addition. And the SMC Pentax-A 645 150mm F3.5 you suggest looks to be a good option for the longer focals. If the GFX were more of my main camera body, I'd opt for the GF110 (assuming good for IR) or the GF120.
Lots to test and try...
Hi Ken, Have you received your converted camera yet? Just FYI, I tested a second copy of the 32-64 and it seemed to perform better in IR than the first copy I tested. The first one was a used lens from B&H and it's possible that it could have been a subpar copy, as the tests of the 2nd copy didn't show any glaring hotspot or sharpness issues from f4 to f8 across the zoom range. A little bit of diffuse hot spotting at f8, but nothing you would notice without a side by side comparison. So definitely test your 32-64 when you get the camera...I suspect it will work just fine in IR.Thanks Josh. This was my thinking as well. It's the IR that causes problems, so the 32-64 should be fine with the Hot Mirror, but definitely will need to test it with all the filters. I'd place bets that if the AR option for the GFX was available from Kolari, the difficulties with the hot spots might be a non-issue. The AR option is available for other cameras, and it is a worthwhile addition.
My Fuji GFX is at Kolari Vision right now getting converted to full spectrum, allowing me to shoot in IR simply by attaching the desired filter. I still need the ability to shoot in color, so the hot mirror filter with full spectrum conversion fills the bill. I'm opting for 590, 720, and 850nm. Unfortunately the AR coating is not an option on the GFX, but hopefully it is not an issue. I plan on using the 32-64 as my primary lens. Filters will be on the Xume magnetic filter system. Fingers-crossed---I'll get the camera back in a week or two.
A Phase One Achromatic just couldn't be justified :loco::grin:
Ken
