Yeah, the low shots are tough with the current 90. My favorite Hasselblad photographer, Platon, uses the waist level finder of the V cameras and I absolutely love that perspective for portraits.I have one.
It's alright, would like to have the ability to fold it down. I really only use it when I want to get a shot from under knee high.
A simple, low tech and relatively cheap Hasselblad accessory. Ideal for low angle shots. Downside is no info in the viewfinder and while it works with autofocus with manual focus there are no focus assist lights. There is also the obvious issue with shooting portrait.Has anyone used the HVM on their H cameras? I miss my 503 and the unique experience.
Shooting 220 Ektachrome with the film back has me wishing I could have kept the 503, but adding the HVM may soothe my longing.:loco:
Hi, Paul,A simple, low tech and relatively cheap Hasselblad accessory. Ideal for low angle shots. Downside is no info in the viewfinder and while it works with autofocus with manual focus there are no focus assist lights. There is also the obvious issue with shooting portrait.
Paul
Dave, no, I meant shooting in Portrait orientation!Hi, Paul,
Thanks for the post. Issue with portraits? Are you referring to the lack of focus assist/confirmation and exposure information?
One of the reasons I am looking at the WLF is to get back to shooting hand held as the V series was always used. I never could get used to shooting the 503cxi, handheld any other way than looking through the WLF.
Ah, yes, I see...Dave, no, I meant shooting in Portrait orientation!
But I guess you are looking to make square images so it will not be a problem for you.
I almost always shoot off a tripod, but back in the day I often used a Pentax 67 with a WLF hand held for candid shots. It always seemed a passive method of working compared to lifting a whopping big beast up to your eye.
Paul
Actually, I tried that today. I think the HVM is a bit more protective though.Most of the time, I can work with just taking off the viewfinder and cupping my hand around the ground glass.
You also don't get metering...Works fine, low-tech but works. You get AF as mentioned but no manual focus assist light.
Yeah, ain't it cool?:thumbup:You also don't get metering...
Neither did I get metering with the V-system.... that is the charm of old Hasselblads and when I am using film in the H camera, a waist level finder, and shooting in the style of photographers such as Platon (with a completely different POV), and I am looking forward to learning as much as possible.
Sometimes, getting back to basics is good.
Actually, I never felt as liberated as when shooting with the 503cxi, and the M3. No batteries, no chargers... No rush. Pure, simple creativity without electronics or all the bells and whistles. I think I am not yet done with the V-system. Or an M.
Until then, a WLF will suffice for those moments when only film will do and I want that style of shooting.
That is certainly interesting!I too really like the V system with the WLF - bought a prism for it once but never used it, just didn't really suit.
I bought an H3D-39 some years back and looked at the HVM finder. Quite astonishingly expensive for what it is - a rigid plastic funnel with a diopter on top (and it doesn't even collapse like the V system one). And from memory I am not sure that the diopter is changeable (unlike the V system diopters) and it certainly is not adjustable to your eyesight.
I also found that hand holding the H3D at waist level was not as pleasurable as my old 503cx. But I still wanted to try and not spend so much money on such a basic piece of equipment which I wasn't going to use daily.
So I bought a really cheap magnifying viewfinder for DSLRs - the type that you attach to the lcd screen at the back and can then view the lcd in bright sunlight. Fits perfectly over the H system screen. Mine has two options, you can swing back the diopter and just have a plastic rectangle over the screen for composition and then swing the diopter back and focus. Works perfectly for low tripod work, but obviously it has no fitting to attach it to the H3D (that actually is pretty much the sole difference between the Hasselblad WLF and it) so not so good for handheld work. However I suppose you might be able to cobble something together with elastic bands or (my favourite accessory) hair bands to attach it more securely. But these are commonplace, cost about $20 at the most basic and work.
That way you can cheaply work out if you really want a WLF for the H system and are prepared to spend the extortionate amount of money that HB charge for it.
Oh yeah!!! Macros!My experience is only from the mighty Fuji GX680. On that camera I would not want to use anyting other than
the WLF. The available mirror finder is awkward and makes the big camera even more huge. I simply love the
magnification of the 6x8 groundglass for precise manual focus through the WLF.
But related to HB WLF : You simply can't beat a WLF for down on the earth macro shots. I could equip my
Mamiya AF with a 90 degree periscope attachement but the magnification would never be as good as a
WLF. So for earthy lichens(moss), mushrooms (funghi) and flowers near the ground there is nothing as good as a WLF.
Of course the WLF on HB is only convenient for landscape shots, the GX680 has revolving backs so the WLF
is usable for landscape and portrait.
