I think they have but they dont want to tell anybody about it. I think waiting for the right moment.Does Hasselblad have an 100S-like camera ready to sell?
Chris,I am puzzled actually. Lets believe what Jim wrote about H lenses not "good enough" for 50 MP sensors. And Hasselblad has been marketing H series cameras with 50+ MP sensors for years.Acc. to blog.kasson.com, most Hasselblad H lenses are good on the 5.3 um sensor of the X1D and GFX if stopped down by +/- 2 stops but at open aperture corner-to-corner they are no match for the native Hasselblad XCD or Fuji GF lenses. With the future 100 MP 3.76 um sensors, that difference in quality will be even more apparent.
Of course you are quite correct in everything you say as far as I am concerned - except for the last line I have bolded - which is the #1 reason I switched to Fuji...Just a meta-comment from my side:
- After following this site and others for a few years, I know that those who constantly look over the fence for another system, eventually will find another system, throw out what they have, take a loss, and declare their newfound love. Repeat.
- The differences between the systems discussed here are marginal, and barely visible to a neutral observer looking at real pictures
- You take the best pictures with the system you feel comfortable with, and that you know.
- I think personal shooting preferences are the most important factor in choosing a system.
- In most cases, post-processing competence will have a larger impact on image quality than choice of MF brand/system.
- You save a lot of money by not changing system, even if your system is "expensive" (aren't they all?), and build it over time.
I do not think Jim wrote that the H lenses are not good enough. He tested the lenses he owned, most of them were not the best ones HB has to offer (e.g., HC 35mm which he actually liked on Fuji) and he tested them all on GFX, not on Hasselblad's cameras.Chris,I am puzzled actually. Lets believe what Jim wrote about H lenses not "good enough" for 50 MP sensors. And Hasselblad has been marketing H series cameras with 50+ MP sensors for years.
Every Phase One IQ4 is calibrated at the factory against a variety of ambient temperatures, ISOs, and shutter speeds. That calibration data is loaded into non-volatile memory. The result is that no dark frame is required at the time of capture, but the end resulting quality of long exposures is exceptional.AFAIK, all manufacturers except Hasselblad 'require' a dark frame subtraction for optimal results when shooting exposures longer than a couple of seconds. That is quite inconvenient when shooting with very long exposures (GFX and X1D max is 60 min).
Hasselblad has apparently designed and tuned its sensor/amplification pipeline so that it does not require the dark frame subtraction (LENR) to produce optimal quality. I do not know more about it.
This implies that if two generations of a camera have different resolutions that the main or most important difference is the resolution.And maybe that we can’t even predict whether 50 vs. 100MP sensors would make an interesting difference for more than a few of us?
Well said.Just a meta-comment from my side:
As dj may already posted : very well said .Just a meta-comment from my side:
With higher pixel counts the difference between AI Giga and other methods diminishes. The real power comes into play with lesser MP files. However it is the only upsampling method I use as it does have the edge over everything else. I upsample my files to 600 DPI so that no other upsampling is done in my printing workflow. At 40 inches that means 24,000 pixels in the long direction. Upsampling a GFX files takes about three minutes on my PC.Victor, your comment about AI Giga is interesting. I bought it in early December, and I have only had the time to try it on one 200% upscale of an X1D file. I compared it to a 200% upscale using PS 2019 with the Preserve Details 2.0 method. I could not see any improvement using AI Giga. I was wondering if you will only see differences with lesser quality files or more extreme upscaling. I gather your experience is quite different.
Thanks. I need to do some more work with it.With higher pixel counts the difference between AI Giga and other methods diminishes. The real power comes into play with lesser MP files. However it is the only upsampling method I use as it does have the edge over everything else. I upsample my files to 600 DPI so that no other upsampling is done in my printing workflow. At 40 inches that means 24,000 pixels in the long direction. Upsampling a GFX files takes about three minutes on my PC.
Victor
LOL! Love it. The gods know this addiction rules our financial future, eh? And "the gods are malicious, tricksy, and swift to thwart..."Probably true. But boring. :ROTFL:
This was a huge selling point for me in moving from the Trichro to the IQ4. That and the LCC process on tech cam.Every Phase One IQ4 is calibrated at the factory against a variety of ambient temperatures, ISOs, and shutter speeds. That calibration data is loaded into non-volatile memory. The result is that no dark frame is required at the time of capture, but the end resulting quality of long exposures is exceptional.
But it's true that, before the IQ4, you had to jump through hoops to disable dark frame reduction on a P1 back.
This sort of thing only matters at exposures of a few seconds and longer, which explains why most manufacturers barely pay attention to it. Imagine the number of prosumers that ever take a multi-second exposure. But for P1 long-exposures have been a key use-case since the P45+.
Hi Erik,With the X-series on Hasselblad, we have calculated MTF data, with diffraction taken into account. But no testing like Jim Kasson has done.
