I received the system, with the 105mm adapter ring. Net, the ring appears to be fine threaded, and after one turn, it will not screw into the front thread on either the Phase One 35mm BR, 40-80 BR, or 75-105, with a 95mm to 105mm step up ring. Instead it binds about about 1 turn. Nowhere enough material has been threaded to safely hold the mass of the Wine county holder, CL-PL and 1 filter, not to mention 2.
In fact, I can't get the adapter ring to screw into any front threaded 105mm filter.
Does anyone else have this system yet using the 105mm adapter ring? If so does it fit into the Phase One 105mm threads. I am trying to see if I have a bad ring, or if Wine Country has made a ring with the incorrect threading to accept a course threaded lens.
Paul C
Paul C
