The far left light in the 25m exposure using the little stopper (6 stops) does not show flare, but a 30m exposure I did using a big stopper (10stops) does have a flare in that location.I see plenty of lens flares which are situated more or less opposite the point sources of light from the centre of the lens, is there something else? I’m looking on my iPad though so maybe missing something?
It was bloody cold out! and I spent a lot of time cursing the LENR phase. The IQ250 is a great back. I am not a fan of it being less than full frame and I was upset that I lost the use of my Rodenstock 35mm (Arca R Mount), I am thinking about getting a 40R for the wide angle and just starting my research on how well the 40R will work on the IQ250.A few thoughts, by any chance was it cool out? and did the lens happen to slightly fog on the front? I have seen similar flare (that is what your artifacts are for sure) due to slight fogging on the front of a lens, especially with bright lighting like you have (mine was sunrise flare).
Still blows me away just how clean the IQ250 sensor is. Phase did a wonderful job on that one. I noticed this from the day the camera was announced. I have not seen as clean a shadow recovery with the IQ150, 3100 or IQ4. And I don't believe that Fuji's 50S can get quite that clean. The recovery on the grass is impressive, not that in this case you would want it.
It's still a mistake that P1 did not enable the E shutter on this back. That would have made a amazingly powerful solution. The fact that both Fuji and Hasselblad did on their solutions using this same chip show that it both can be done and done very well.
Paul C
It was bloody cold out! and I spent a lot of time cursing the LENR phase. The IQ250 is a great back. I am not a fan of it being less than full frame and I was upset that I lost the use of my Rodenstock 35mm (Arca R Mount), I am thinking about getting a 40R for the wide angle and just starting my research on how well the 40R will work on the IQ250]
The 40 will do very well. 20mm of shift horizontal.
There is no excuse that P1 could or would not turn off the mandatory dark frame.
On both the 3100 and all 50mp backs.
Everyone else using this chip figured out a way to do it just fine.
Paul C
The waist-level finder must be closed, then no light comes in........................
Has anybody ever noticed light leak with the waist-level finder?
Closed it was. So I’ll see what Lee Filters has to say and do a little more testing.The waist-level finder must be closed, then no light comes in.
Greeting Gerd
