Backfocus problem with Hasselblad HC 35mm
Maeda
Hello,
I just received a 35mm HC lens (second hand) for my H5D50c and i have unfortunately a problem of backfocus.
As my 100mm is perfect with the camera this is a lens problem.
Did you ever had that problem of backfocus ? Is there a remedy ?
Thx !
Maeda
Thank you for your replies.
So this is something which need a repair.
Hopefully the lens is still under warranty.
Steve Hendrix
It may or may not need a repair, and it may or may not be restricted to only the lens itself (though it sounds likely). In any event, if it goes in for evaluation, you'll be closer to getting to the bottom of the situation.
Steve Hendrix/CI
