dougpeterson
Shadow color quality, shadow noise, and shadow gradation are all sides of the same coin*; as you see in the raw, frame averaging improves the shadows across the board. Looking at the JPGs online the difference is meaningful but relatively subtle; looking at the raws the difference is really quite something.Thanks to DT for the 50 iso raws. After downloading and really going over the seashore shot, the results are both interesting and impressive.
The seagulls in flight are gone, as are the objects (foam cluster) on the water in the averaged shot. The color appears more pleasing to the eye also. As for noise, yes, the darker cliffs do show better in the frame averaged shot, however what catches me eye is the fact of how much more shadow gradient is available. The noise is less also, but the shadows show more color if that is possible. The water also takes on a more pleasing color but not sure that was something done in post. Adding a bit of sharpening with Topaz really pulls the darker cliffs out for more details, and no noise.
Do note, while we appreciate your thanks, credit for those raws goes to the talented Paul Reiffer. I've done a lot of beta camera testing and it's very challenging to create a good test image 1) on the short timeline such things must be done on 2) demonstrates the technical attribute that is meant to be demonstrated 3) looks pretty.
*I guess that makes the coin three sided? My metaphors get worse as the day wears on.
