Results 1 to 9 of 9
Thread: Leaf donor
    Mar 2019
    22
    Leaf donor
    Hi Guys i have a leaf Aptus II 12 80 and i need to change the firewire board. To have it fix by phase doesn't make sense($3500) so i was wondering if anyone knows which other leaf back has a similar board(i was thinking the Aptus II 8 but i am not sure).
    Thank you
    Massimo
    Oct 2018
    46
    Re: Leaf donor
    If your have problems with the board, you might want to consider reflow'ing the solder. This is where you use a heat gun and a laser thermometer to heat the board to 230c for no more than 90sec this can fix dodgy connections. Only do this if its a single sided board the right way up. if you add a photo of the board i can tell you if its ok to do Physical sockets always end up with bad solder connections due to physical shearing and twisting :-)
    Mar 2019
    22
    Re: Leaf donor
    Quote Originally Posted by earburner View Post
    Here it is, thank you.Click image for larger version.
ID:	142677Click image for larger version.
    Senior Member DougDolde's Avatar
    Oct 2015
    Joshua Tree, CA
    896
    Re: Leaf donor
    I'd pay to have it fixed. Kinda like trying to be your own surgeon
    Mar 2019
    22
    Re: Leaf donor
    Quote Originally Posted by DougDolde View Post
    Problem is that financially it doesn’t make sense at 3500 for a back that is worth maybe 5500 and they are the only one that can do it, there’s no replacement parts or circuit blue prints around to have someone else do it.
    Jan 2011
    Denver, CO
    132
    Re: Leaf donor
    Quote Originally Posted by photomassimo View Post
    I'll crack my Aptus 75 open tomorrow evening and let you know what I find. I'd be a little surprised if this part didn't remain consistent throughout the Aptus lines.
    Oct 2018
    46
    Re: Leaf donor
    So looking at your photos, you will need to isolate the board from everything and disconnect the ribbon cable (it wont take the heat) so you need to get the board as close as it can be to how it was manufactured, very much looking out for things that don't like the heat. Circuit boards are put together with robots placing the components on the board with a bit of solder paste and then run though a flow oven melting the solder paste. Then they are hand finished adding things that cant be flow soldered (these are the things to look out for) like the ribbon cable. You can concentrate heat around where you think the problem is i.e the firewire socket. I would say be very touchy feely when doing this, warm it up a bit and look out for problems (smoke or burning smell is not a good sign) the laser thermometer is a must for checker around the board for hot spots. I have fix a few things doing this, I first fixed my PS3 there are many youtube videos out there on this. also let it cool down slowly, not moving it for 5 mins :-)
    Mar 2019
    22
    Re: Leaf donor
    Quote Originally Posted by freaklikeme View Post
    Thank you!
    Mar 2019
    22
    Re: Leaf donor
    This is the piece that is broken, is in any leaf Aptus II and some others.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	142894   Click image for larger version.
