Hasselblad XCD 21mm f/4 in-depth review
vieri
Ladies and gentlemen, I just published my Hasselblad XCD 21mm f/4 in-depth review, the first of a series of reviews that will examine all Hasselblad XCD lenses I own.
Read on to find out what I thought of the Hasselblad XCD 21mm, the widest native medium format lens available on the market!
https://www.vieribottazzini.com/2019/07/hasselblad-xcd-21mm-f-4-in-depth-review.html
Looking forward to your thoughts and comments. Best regards,
Vieri
  • Like
Reactions: med
danlindberg
Agree it is an impressive lens and I can see someone buying into the system because of it. It really is that good!
vieri
It sure is, Dan, and personally I am one of those that started considering the X1D because of this lens (and electronic shutter). Best regards,
Vieri
Shashin
I can't speak about the lens sharpness, but your atmosphere is very clear and stable!
SrMphoto
Vieri
Thanks for your blog posts. Why do you care about electronic shutter? Are you using adapters?
Paratom
Thank you for the review!
I also own and like this lens, even though for me it is a tad too wide sometimes. While I can crop I think there would also be room for a 24mm focal length.
Overall I really like the x1d a lo because of its simple user interface but more important because of the compact size/weight and portability.
The x1dii seems to improve exactly the points which are important to me, so I am very tempted to get that (if the speed advantages are big enough).
vieri
:D Well, I went out early morning, when the air is at its cleanest (and when it's not too hot around!)
Thank you very much. Yes, I do use adapted lenses, i.e. the Voigtlander 15mm (which works great), some Leica M / R lenses too. For landscapes and using long exposures, there is no problem at all with ES (banding, flickering and so on), so it's a great option to have to expand the native lineup.
You are very welcome, I am glad you enjoyed it :) I definitely see your point, even though personally more than a 24mm (19mm equivalent) I'd rather see something like a 26mm (21mm equivalent). That would give us the equivalent of 17, 21, 24, 35, 50 (not considering the teles) which is a pretty good lineup in the wider-than-normal range :)
Best regards,
Vieri
vieri
To me it was essential that it has ES. I am using it in combination with Alpa and aperture mount only lenses.
For me as well, I love the possibility to adapt non-native lenses when needed. Together with the short flange distance, it opens up a lot of possibilities to get different "looks" in your images :)
Best regards,
Vieri
