rdeloe
I'm using a Fuji GFX 50R on the back of a Toyo VX23D. I understand that shorter focal length lenses designed for view/tech cameras will not work due to lens cast problems when shifting (even if they physically fit in front of the sensor). Therefore, I've given up on most of them... except I hold out a faint hope that a Rodenstock Apo-Grandagon 55/4.5 or its Sinar variant will still allow shifts without lens cast issues.
I've found lots of threads on getDPI and other sites that hint that the Rodie 55mm won't work on a GFX sensor, but nothing definitive. So this post is seeking a definitive answer. Is anyone actually using the Rodenstock Apo-Grandagon 55/4.5 on a Fuji GFX 50S or 50R, and if so, how does it do when shifting?
If the answer is that it doesn't work, then I'm going to go with either the SMC Pentax 67 55mm f/4 or the Mamiya C 50mm f/4 shift (depending on which one performs better -- to be determined once I round up the necessary adapters). However, these are both huge big lenses -- so not my first choice.
