Page 4 of 4 FirstFirst ... 2 3 4
Results 151 to 167 of 167
Thread: MF Digital Precision
  1. #151
    Los Altos, CA
    10,486
    1031
    Re: MF Digital Precision
    Quote Originally Posted by tashley View Post
    It is my impression that the shutter on the Phamiya has a hell of a whack. Does anyone else have good comparison experience with anything else?
    Not wanting to start a war, but I can tell you my Contax 645 was far worse for whack and so was/is the Mamiya RZ.
    Re Hassy, perhaps Dave or Marc can clarify this, but I believe the regular H1 and H2 have film curtains that need to move out of the way prior to exposure and that motion coupled with the mirror flopping up have a good deal of inertia on those bodies. However, I think the D version bodies eliminated this curtain (and why they cannot be used with film?) which also shortened release-lag and eliminated a fair amount of motion.
    home: www.getdpi.com
  2. #152
    Austria, close to Vienna
    3,869
    Jack,
    Do you think / know, that the new Mamiya/Phase camera, which will be available this summer and can only take digital backs, will also have no curtan and thus be better WRT motion?
  3. #153
    Los Altos, CA
    10,486
    1031
    Quote Originally Posted by ptomsu View Post
    Jack,
    I doubt it. A camera with a focal plane shutter does not need the film dark curtain as the shutter itself solves that issue. But, the new shutter may be lighter in weight and/or simpler and thus have less inertia as a result.
  4. #154
    Feb 2009
    154
    Several years ago I wanted to try out medium format and rented a RB67 + 50mm lens. I made night-architecture- and museum-shots (1/8s-8s), all with my very stable 4kg Manfrotto. I couldn't find a mirror pre-release and so I shot without it about 5-10 rolls of Velvia/T-Max.
    When I got the slides I was shocked: They were ALL unsharp! 2 days of shooting and about 300DM wasted!
    Mamiya RB67 was dead to me (despite it's issues with seize and build quality) and this was the very last time I thought about not using mirror-pre-release on ANY SLR!
  5. #155
    8,498
    44
    Quote Originally Posted by georgl View Post
    You need the dual cable release for the Mamiya 6X7s to engage the mirror release ... that mirror is huge and quite damaging to any precision type work. It is very precise with the mirror released and waiting a bit before shooting.
    It is amazing to see the effects of movement when you are sure there is none. It's really annoying to learn this stuff on the job.
    I've mentioned this before, but I once did what's called "pin registered" animation, where a sequence of images are shot using a locked down camera so the background remains static, while the subject moves in increments. When we layered the sequence and ran through the action, the background was jumping all over the place! We had to use a much bigger tripod and sandbag it like crazy, put the mirror up, use longer cable release, and make everyone stop dead in their tracks during the sequence of shots ... even grips working in the next room ... even a cement floor moves when you walk.
  6. #156
    Los Altos, CA
    10,486
    1031
    FWIW, you only need a normal single cable release to do the mirror-up on an RB/RZ -- just be sure to stick that one on the lens. Once you've done that and screwed it down, the normal release button will send the mirror home waiting for you to trip the shutter via the release on the lens.
    But yes, that camera is horrible at 1/4, 1/8th and 1/15th without it, and I've even avoid 1/30th and 1/2...
  7. #157
    Subscriber Member tashley's Avatar
    Jan 2008
    South of England
    3,295
    Thanks Jack. I can believe it. I haven't shot a MF body other then the Phamiya for quite a while now so I have no other points of reference - other than the purely subjective feeling of the HD I tried in the shop, which seemed very clean but then you'd expect that!
    Best
    T
  8. #158
    carstenw's Avatar
    Berlin, Germany
    2,530
    Hmm, my Contax 645 feels very well damped, and when I try various combinations of mirror lockup and Bulb, it seems that about 2/3 of the whack is bringing the mirror back in place/recocking the shutter. At what shutter speed was the Contax worst?
    Now my Hasselblad 500C and 2000FC/M give mighty thunks. By comparion, the Contax doesn't feel that much worse than my M8.
    Carsten - Website
  9. #159
    3,869
    Thinking back to my analog days - I actually had NEVER problems with shutter vibrations on my Contax 645 system!
    If the Mamiya's are better then Phase cameras are better and then I also should have no issues.
    Think all really depends on how you operate and hold a camera maybe I have the right trick - do not knw
    I get more and more attracted by the Phase system - Phase camera (new one coming this summer) plus 45+ back and 28 / 80 / 150
    And kind of a arguably reasonable price for me
  10. #160
    23,623
    2555
    Get a P25 Plus to start. Great price on one. LOL
    Be surprised how good 22mpx sensors are. You should reread this thread
    http://forum.getdpi.com/forum/showthread.php?t=4333
    www.guymancusophotography.com
  11. #161
    Melbourne, Australia
    2,338
    52
    the more capable the resolving power of the chip - the more obvious the weakest chain in the shooting becomes. The more discerning the eye - or the more important fine detail is ..again - not surprised.
    I freaked out when I first switched form Canon 1dsmk1 - to mk11 - had to modify my shooting to cater for it. Now the MFD is pretty much confined to fat light or tripod situations.
    Still ( fortunately for me) I dont have a very discerning eye for such matters - sometimes I wonder if we dont set the benchmarks so high that we just find another reason to beat ourselves over the head about..
  12. #162
    23,623
    2555
    True one reason I like the P25 plus or the 9 micron sensors in particular is it is very lens friendly. You can use almost anything on it and get great results than forget about everything else. It is so close to the p45 and p65 backs that I really find no need for more. I need the P30+ for different reasons and detail is not one of them. My conclusion after a full year shooting MF digital is this we are so far above the 35mm curve line that almost any back you use will be extremely good and all we are really talking is very very small detail as you go up in size. Most of this difference will not show up in print unless you get REALLY big. Sometimes I really question this and in 35mm it was so important to get the absolute finest and best resolving power lenses and in MF that is NOT the case. I have said this at least several times on this and other forums. The step up is truly a step up and way beyond what 35mm can do. MPX is such a BS guide line that manufactures go by and us consumers buy into the hype. My lonely 10 mpx DMR beat the crap out of anything you could put up against it in 35mm in it's day even. It means very little in MF, good lenses will never hurt you ever in any system but I find this less important in MF than I ever did in 35mm. Different ball park different city all together and not even in the same country. I don't care what back anyone buys the difference is huge over 35mm. Not just resolution either but everything that counts. Frankly you could hand over ANY MF back to me and i would be a happy dog with my tongue hanging out. I know many folks on this forum alone that feel the same way. I go back and look at files that I shot and am just amazed at what we get out of these backs, sure the P65 is a awesome back and love to have one but maybe more for king of the hill thinking than real life working. Almost any back in the market will render a 30x40 print with no issues. You want bigger than stitch.
  13. #163
    Aug 2008
    Carmel/Tucson
    2,355
    Quote Originally Posted by PeterA View Post
    I freaked out when I first switched form Canon 1dsmk1 - to mk11 - had to modify my shooting to cater for it. Now the MFD is pretty much confined to fat light or tripod situations. ....
    I have found this to be so true. And similarly when I added the 1DsMkIII to the fold with my 5D....
    And now even moreso with the P65+. I found the transition between my previous medium format backs to be simple--- Kodak 645M to P30 to P45+ Easy and no change in approach or workflow. Not true with the P65+
    Proper hit-and-run landscape photography was perfect with the P30 and P45. The P65+ has a small learning curve or adjustment period that I didn't expect. It certainly makes you slow down and think a bit.... I guess perfect for an aging body that isn't hiking as fast now...
    And IMHO, Guy is right. Any MFDB trumps a 35mm based DSLR. It's just a different format and feel altogether. Many shooters would just love to have any MFDB in their hands.
    Guy---you're gonna love the Phase Pee-30 + (had to do that). But Guy---you're in trouble, because I really think the Sensor+ capabilities of the P65+ really do suit you....
  14. #164
    2,338
    52
    Totally agree with you Guy - and I have doen the hard yards myself and paid up with hard cash myself to test ALL the systems. Now I have 3 backs and 6 different camera systems and lens collections just in MF..i'd seel some stuff if prices hadn't collapsed so much - something that I wasnt planning for!
    I just posted a longish response to Peter in another thread about exactly this topic - I think we must be reading from the same playbook.
    Really it all boils down to what we already knew:
    1. Any MF back used appropriately delivers in bucket loads of IQ.
    2. All Mf lens systems are good and better than good
    3. Choose a dealer you want to do business with and is capable of helping
    4. Make sure you understand that error in technique will make the MF digital back show up your every flaw. For many uses - this means that the typical shooter is probably better off shooting with 35mm cameras! eg tele, eg low lihht, eg when you need IS, fast shutter speeds etc etc etc ( not to mention MUCH smaller files!)
  15. #165
    23,623
    2555
    I know I like the Sensor Plus idea and in my case i could actually really use that shooting these event gigs. I don't need the big files and actually it hurts processing time on deadline. I actually use the S settings for the smaller file to deal with. Sensor plus a 15mpx sensor is perfect and with the high ISO right up my alley. Just money is to tight right now otherwise it makes sense to me at least , some folks it does not.
  16. #166
    Los Altos, CA
    10,486
    1031
    Peter,
    This is so true it bears repeating. There is a learning curve and it doesn't come instantly -- it requires some effort. Folks that expect DSLR convenience from MFDB's will be severely disappointed... To obtain optimal results from MFDB's requires that one utilizes optimal (read exercises perfection in) capture AND processing technique.
  17. #167
    California/Thailand
    1,206
    Peter,
    Interesting that you picked this point out too, Jack. As I was reading down this thread this a.m. I was going to quote item #4 of Pete's list too, and say that this fits my experience as well. I does really bear repeating, as you say. It's real.
