Hasselblad XCD 135mm f/2.8 in-depth review
vieri
Ladies and gentlemen, I just published my in-depth review of the Hasselblad XCD 135mm f/2.8, both with and without the X Converter 1.7.
The page is here:
https://www.vieribottazzini.com/2019/08/hasselblad-xcd-135mm-f-2-8-in-depth-review.html
In short, the lens is spectacular both without the converter, as I expected after reviewing four XCD lenses, and surprisingly with the converter a well. Once more, Hasselblad went for a pretty unique focal length for a prime, in the MF arena where nobody else offers such a lens, offering a very classical 105mm / 180mm FOV equivalent (with and w/out converter).
Looking forward to your thoughts and comments. Best regards,
Vieri
Sanford Lavine
Vieri,
Thanks! When you said “in-depth” you weren’t kidding. I can’t wait to see your images from this lens after your next adventure.
Looking at the specs I noticed the 135mm was shorter and lighter than the 120mm and 2.8 at that. I do like the 120mm for close-up work.
This lens is now on my list. And thanks for the info on the 85mm filters, they may be what I can use on my Leica M lenses on the SL.
vieri
Vieri,
Hello Sandford,
thank you very much, I am glad you found it interesting :) About filters, one of the great advantages of the XCD lenses, all of them so far, is that you can use 85mm filters with no vignetting - and if you also use M lenses, that makes it a no brainer. Of course, if you already have a 100mm kit, you can use that as well.
Best regards,
Vieri
