Thanks for the clarification, Steve. From my notes from a recent inquiry I had $2899 for t/s mount but would be happy to be wrong about this!John, closer to $2,100.
Steve Hendrix/CI
John
Steve Hendrix/CI
From our article here: https://phaseoneiq4.com/11-reasons-tech-camera-users-will-love-the-iq4/Curious to know what advancements specifically for tech camera users are pretty staggering. I have both and other than megapixel count and little better on the lens cast, I don't know what else the advantage for tech camera is.
I would just temper this slightly by saying the color cast is greatly reduced. The amount of reduction is such that most people with most lenses with most movements will not find the color cast warrants an LCC.IQ4 tech camera advantages
1. With wides literally no color cast and nominal light fall off.
Thank you Ken, Felix and I are talking Saturday! I have heard so many good things about the Cambo WRS 1600.Felix is a known seller and GetDPI family member. The IQ3 is an excellent value.
Another option-----check in with Phase One dealer's on possible trade-ins on the IQ3 for the IQ4 150. Buy the IQ3----and trade in for the IQ4 can save a substantial amount of money.
Both IQ3 and IQ4 are awesome MFDBs----you really can't go wrong.
If you haven't tried the various technical cameras, I would definitely try Alpa, Arca, and Cambo to see which suits you best. I prefer the Cambo WRS 1600. The HR40 t/s remains my main lens.
ken
John
Perhaps my "little bit better" was understated and should have been "better".From our article here: https://phaseoneiq4.com/11-reasons-tech-camera-users-will-love-the-iq4/
I'm very surprised to hear you say you find the lens cast reduction only "a little better" - can you explain a bit more?
- Much less color cast / falloff
- Improved live view
- No need for manual dark frames
- Frame averaging for almost zero noise
- Increased Resolution
- Faster ES
- Focus Mask in live view
- Live Raw histogram in live view
- Faster image navigation during review
You have both; do you not find the above to be very useful? The first four are what I've found personally to be "staggering" in impact of my own tech camera shooting. They equal much less hassle and a much smoother shooting workflow in my experience.
Notably there are two current disadvantages of the IQ4 vs IQ3 on a tech camera: longer boot times and no zero-latency triggering for copal shutter sync.
And I probably should have used a word other than "staggering" which sounds marketing-ish anyway. I still think "significant" or even "very significant" is warranted, based on broadly sourced feedback from our clients. But of course, as you point out P1 still has some items on their to do list for the new platform (ad hoc wireless, zero latency), which, if they effect your needs/use are also significant. How significant any of these given pro or con is will depend on ones needs/wants/workflow.Perhaps my "little bit better" was understated and should have been "better".
There is no question that IQ4 150 (cost as no object) is the best DB for Tech cameras ever. Having personally moved from an IQ180 to the IQ4 I can attest it was a chasmic jump with many positive gains. That said on a budget the IQ3 100 is a great back at a fabulous price point, and you need to buy a camera and lenses...lenses will kick your budget so choose wisely.And I probably should have used a word other than "staggering" which sounds marketing-ish anyway. I still think "significant" or even "very significant" is warranted, based on broadly sourced feedback from our clients. But of course, as you point out P1 still has some items on their to do list for the new platform (ad hoc wireless, zero latency), which, if they effect your needs/use are also significant. How significant any of these given pro or con is will depend on ones needs/wants/workflow.
Agreed. Your input is always valued and appreciated.And I probably should have used a word other than "staggering" which sounds marketing-ish anyway. I still think "significant" or even "very significant" is warranted, based on broadly sourced feedback from our clients. But of course, as you point out P1 still has some items on their to do list for the new platform (ad hoc wireless, zero latency), which, if they effect your needs/use are also significant. How significant any of these given pro or con is will depend on ones needs/wants/workflow.
Paul,IQ4 tech camera advantages
2. 35XL can be used on center without CF unless subject has solid color like blue
sky. 35XL was pretty hard to use on the 3100 at least for me.
3. No dark frame needed, IMO a huge advantage in the field.
4. Light fall off areas on shifts have less noise.
5. Frame averaging can be used in certain situations for extremely clean files.
6. Focus peaking can help quite a bit.
IA4 tech camera disadvantages
1. Live view at 100 percent view is not sharp or detailed. Harder to discern sharp
focus.
2. Auto exposure live view is buggy pulsing between too bright too dark.
3. Exposure simulation is not useful in low light due to frame rate.
But right now the 3100 is priced to sell.
Paul C
I used to use the H system but was forced to switch to the XF when the IQ4 came out. I was very reluctant and not looking forward to the switch. Now I love the XF and wish I had switched earlier. The camera is great to use and I actually use many of the gadget type features that it has built-in which is something I'm not usually akin to. The camera and lenses are really good.For those of you with the digital back/tech camera setup, would you also recommend getting the XF Camera?
Thanks in advance,
Greg
If the choice is between getting the XF vs a better lens (32HR or 90HRSW for example), then I'd go with the lens. However, whilst I often joke about the XF being built like a boat anchor, it is a very flexible and high performing body for an IQ back. You'll obviously need to consider what lenses you'd want for the XF too and that can be potentially another money pit.For those of you with the digital back/tech camera setup, would you also recommend getting the XF Camera?
Thanks in advance,
Greg
Dana, thank you for your insight!I used to use the H system but was forced to switch to the XF when the IQ4 came out. I was very reluctant and not looking forward to the switch. Now I love the XF and wish I had switched earlier. The camera is great to use and I actually use many of the gadget type features that it has built-in which is something I'm not usually akin to. The camera and lenses are really good.
Graham, thank you for insight! If I were going to have 3 lenses on my radar for the technical camera, which 3 would you recommend. My primary use is landscape and exterior commercial architecture.If the choice is between getting the XF vs a better lens (32HR or 90HRSW for example), then I'd go with the lens. However, whilst I often joke about the XF being built like a boat anchor, it is a very flexible and high performing body for an IQ back. You'll obviously need to consider what lenses you'd want for the XF too and that can be potentially another money pit.
I'm glad that I have an XF along with my Actus DB2 but I typically use the tech camera 99% of the time. If all else fails, with the XF you'll have a great piece of weight training gear! :ROTFL:
