As have I, since the new MBP came with it installed. The point is...no thanks to or help from Capture One.I've been using it on 2 machines on 10.14.6 for quite a while with no issues.
I get your point, but since there is not much we can do about that (whether you just got an answer from an incompetent employee or because Phase One may really be in shambles) I wanted to share my experience with the aforementioned OS in case it was useful.As have I, since the new MBP came with it installed. The point is...no thanks to or help from Capture One.
There are some actual issues with Catalina as well with large imports, Capture One eventually crashes with a segmentation fault when enumerating many files.As have I, since the new MBP came with it installed. The point is...no thanks to or help from Capture One.
Long term tech user here. Had an XT demo the other day.
It's all about the shutter, nothing else is remotely that special.
The shutter is great - quite, quick and very minimal. The one and only reason to consider this 'system'.
The XT body - quite honestly I feel Alpa has a better range of tech bodies.
some things clearly wrong:
- No cold shoe, and nowhere to put something like, oh... an optical finder?!
- The silly rotating mount that gets in the way 90% of the time.
- Small range of movements: No body option with more, no body option with none/less.
The lens choice is abysmal right now. Badly need to ramp that up, or at least announce the pipeline - this is not a 'system' as it stands.
Roddy 50mm and 90mm are badly needed.
Glad to hear the shutter will be released to Alpa, Arca and others. Hope that is true.
But just to repeat: the shutter is the star. If that lives up to the promised reliability, then it's a real positive.
What about the workhorse 40?Long term tech user here. Had an XT demo the other day.
40mm is a waste as there is a 32mm already!What about the workhorse 40?
40, 70 and then 138-terrific 3 lens kit.
Steve, thanks for your responses.I agree the X shutter is the real hero. There are no other shutters! Copal is gone, Sinar e250 is in limbo ... We needed a shutter, and this is a very good shutter.
There is the ability to mount a cold shoe to the XF with the Cambo Accessory Shoe Holder:
https://www.digitalback.com/product/accessory-shoe-holder-with-2-point-fixation/
I suspect they discussed the top mounting options, for an optical viewfinder, for example, and chose to not include that option, given that size seems to have been a driving force behind the design. I feel that optical finders are valuable for some of my clients, but I have sold very few in recent years.
What "silly rotating mount" are you referring to that gets in the way?
I do agree that Phase One would benefit by announcing a lens roadmap sooner than later.
Steve Hendrix/CI
Would have been better if the digital back (mount) could rotate, this way rotation would be independent of any shift movements. Now any shift moments also rotate. (More of an issue if tilt would have been possible.)The rotating mount is ... the tripod mount that rotates through 90degrees when you want to do a vertical. Why not simply attach the back in a vertical orientation!!,
I’m a little perplexed by this.Would have been better if only the digital back could rotate, this way rotation would be independent of any shift movements. Now any shift moments also rotate. (More of an issue if tilt would have been possible.)
Being only be able to reverse the digital back has the drawbacks that the digital back has to be taken off the camera (dust?) and in that only two positions, vertical or horizontal, are available.
(Terminology: "rotating back" - revolves in place; "reversible back"- can be unlatched, turned 90 degrees, and latched back.)
Yes - a complex piece of engineering, but like so many things Phase does, I think it has a purpose that may not be initially seen.Steve, thanks for your responses.
2: The rotating mount is, (am I really having to explain this?!) the tripod mount that rotates through 90degrees when you want to do a vertical. Why not simply attach the back in a vertical orientation!!, like you can with Alps, Arca, etc? Its an over-engineered solution for a non-problem. Plus it makes the body heavier and ungainly and its fugly as heck. (You say they probably didn't put an accessory shoe on there as 'size was a driving force'... yet they put this on there?!)
1: The accessory shoe needs to be mounted onto the camera body, not onto a 'compendium lens shade' that is just a plain bad design. (and ridiculous that you have to buy a $655 !! hood that you likely don't want, in order to attach a $105 accessory shoe!) Oh and it isn't simply for a finder - you may want an iPhone, a video monitor, a level, or... a finder ! Major oversight.
I like the lens shutter solution. It's great, but please don't over-sell it: we all managed fine with out Copals, and continue to. More importantly, people are mostly using ES now, and that will just get better and better. This shutter is quiet, with minimal vibrations, but ES has none and is totally silent.
Steve of the shutter is so great, why no great warranty... I still think a 12k lens should have a 3 year warranty as STANDARD!
Steve, please see my note above regarding the design/movement recording. Do you have any comment on this please? I'm genuinely interested in the other reasons other than 'weather exposure'I certainly didn't mean to "over-sell", as you say, the X Shutter by calling it a very good shutter. But they solved a problem that needed solving. And it is an extremely robust shutter - we've been told that they have never experienced a failure below 900,000 actuations. Aperture Mount for Electronic Shutter works great for many, but not for everyone. And copal shutters are history. Yes, everyone got along fine in the past with copal, but they're gone. What does someone buy if they want a new lens and need more than the Aperture Mount offers? I feel that the development of the X Shutter is very important.
Steve Hendrix/CI
Although I don’t have the PhaseOne XT, I do have a Cambo 72/50 which allows rotation from vertical to horizontal in a manner similar to the XT (at least as best as I can tell from various snippets). I find this feature to be extremely useful as I don’t like the idea of having to take off the DB and then to reattach it in the other position. As I’ve never used the XT though, I could be wrong...2: The rotating mount is, (am I really having to explain this?!) the tripod mount that rotates through 90degrees when you want to do a vertical. Why not simply attach the back in a vertical orientation!!, like you can with Alps, Arca, etc? Its an over-engineered solution for a non-problem. Plus it makes the body heavier and ungainly and its fugly as heck. (You say they probably didn't put an accessory shoe on there as 'size was a driving force'... yet they put this on there?!)
Jacob
Is the grip made out of Crayon or wax?View attachment 144756
Steve Hendrix/CI
Your's is a good question so I just tested, and looked at how C1 is handling the movements with rotation...By allowing the entire camera plate to rotate (with the shifting dials) my guess (Steve, please correct or chime in here) is that the system doesn't care if the back is in horizontal or vertical orientation, it records the movements as positive or negative regardless of X or Y.
A
