Results 1 to 4 of 4
Thread: Credo/IQ3/Stackshot/SK ES - triggering
    Apr 2012
    135
    So I'm trying to rig up a stackshot to my Credo/Actus/SK ES controller and it appears that both the stackshot and the controller employ the same port on the Credo back. I really don't want to manually fire after every movement, so I'm trying to figure out a workaround, however messy that might be.
    Assuming the Stackshot gives the fire command - if that's plugged into the back and the flash sync port on the back is connected to a Profoto Air transceiver.. is there a way to connect the output of the transceiver to the PC cable input on the shutter controller?
    Or will I get black frames..
    Not sure how to go about this :/
    Jul 2016
    422
    Re: Credo/IQ3/Stackshot/SK ES - triggering
    Quote Originally Posted by colorspace View Post
    Try this.
    https://www.amazon.com/DSLRKIT-Flash.../dp/B0078ZCX6Y
    Apr 2012
    135
    Quote Originally Posted by Boinger View Post
    So rather than going into the transceiver from the back and then out to the controller, this would go from the flash port on the back and split one way for the flash and the other way for the controller?
    Jul 2016
    422
    Yep. Would have the same effect I think.
    I use one of those in my make shift wake up cable. I have it wired to a remote + lens sync cord.
