Results 1 to 20 of 20
Thread: How to remember shift values
    Jan 2019
    29
    as I can enter shift values in C1 when using a TechCam. How do you remember the values you used for a shot? Pencil and Paper? Is there an App for this? Don''t note it all?
    How big is the difference in Image Quality if you enter shift values vs. don't enter it?
    Thanks for your input
    Frank
    Oct 2008
    Munich
    1,136
    Re: How to remember shift values
    iPhone photo of the scene and of the back of the Camera. If I do more I record it in a excel.
    Christopher Hauser
    http://www.chauser.eu
    pegelli's Avatar
    Dec 2010
    Belgium
    3,570
    I don't have any shift possibility but when shooting film in the field (M2) I record lens, time, aperture, filters etc. on paper and later add it as keywords to the scanned digital files. I've been thinking about adding it with an EXIF editor but so far haven't taken that step yet.
    Oct 2015
    43
    Sometimes it's obvious (leveled camera, clear converging lines in scene) and a 1mm sensor-scale grid in Capture One shows the offset from center. Other times I take a zeroed shot for reference.
    Vancouver, WA
    6,460
    627
    Notepad or notes on iPhone.
    ok, these days it’s on the phone ...
    The World is a book, and those that do not travel read only one page ...
    Apr 2013
    Atlanta, GA
    977
    It would be nice if manufacturers allowed you to enter the values into the EXIF data via the back. Maybe someday....
    Member mristuccia's Avatar
    Oct 2017
    Berlin
    131
    8
    Maybe a voice record (or dictation) on mobile phone is the fastest way.
    But you gave me an idea.
    One can annotate only 4 values: lens, image-progressive-number, horiz-shift (+ or -), vertical-shift (+ or -). One image per line, parameters separated by commas.
    Then it will be very easy to develop a small utility which takes those annotations and automatically writes them in an EXIF attribute of the respective files...
    Marco Ristuccia
    photography.marcoristuccia.com
    "Unconcerned but not indifferent."
    Aug 2012
    1,688
    I have never done it, hence I don't use that function i C1.
    Do you see any improvements using it?
    Peter
    Instagram
    My website
    Aug 2008
    Jonesboro, Arkansas
    280
    To show my ignorance here, not only have I never done this, I did not know there was a need to. What does this correct? If the back is rotated into the vertical/portrait position, does the way you enter the XY axis data change?
    Thanks,
    Greg
    Since my original post, I did find this video that gives a very brief description beginning at 1:40, still not sure I fully understand.
    https://www.youtube.com/watch?v=sdBpJ5lbbk4
    May 2012
    2,959
    3
    In bad weather instead of bringing out my iphone I use water repellent paper and pen available from B&H.
    RiteintheRain
    P.S. I also use this to record Frame Averaging image numbers since Phase cannot yet come up with a simple icon to indicate which images have been frame averaged. Plus I can add here # of frames and times, AND of course lens used.
    If Phase can do it with focus stacking and other techniques why not Frame Averaging? Are you listening PHASE?
    Apr 2016
    476
    I tether in the field (yes, crazy, I know) so can enter the shift values in C1 as I go along. If I remember, that is. It would be nice to enter this info directly on the back, however, as entering the info on the computer can sometimes involve moving back and forth between tabs.
    Keeping track of shift is also useful information for compensating for distortion, assuming the lens corrections are calibrated for shift. I also find it helpful to record shift values as this makes it a bit easier to pair up LCC and image files when processing. I sometimes color code the files on the fly (e.g., green for positive shift and red for negative shift) when I'm too rushed to switch tabs and type in the values.
    John
    Senior Member dchew's Avatar
    Feb 2011
    Northeast Ohio
    1,386
    I've never used the info for anything other than telling all of you how far it was shifted in the Technical Camera Images thread. Most of those are 18mm each way for the two image stitched panos. If it is rise/fall then they are, um, guesses.
    Dave
    davechewphotography.com
    Member alatreille's Avatar
    Jan 2015
    Vancouver, B.C - Melbourne, Aust
    22
    A clumsy method, but means I have a permanent record.
    I've been doing this for 5 years and keep a folder of the photographs saved with each project we've completed.
    I for one am hoping with the next firmware update I'll get to punch in the details on my back.
    May 2012
    2,959
    3
    To add more to the wish list (which I believe we should have had on the Q3) is FL of lens used.
    I use 5 lenses and code their use as follows via the only data we can enter to date----f stop.
    [email protected]
    [email protected] or code as f9 [email protected] f8
    [email protected] or code as f13 [email protected] f8
    [email protected] or or code as f15 if @f8
    [email protected] or code as f17 if @f8
    Sep 2017
    on a mountain
    88
    4
    The data for the XY shift are important for lens correction. The lens correction is always made out of the middle in the standard. If the image is shifted in the XY direction and the objetiv correction is done from the center, it will hurt the image more than it helps.
    If I have the GFX on a technical camera I use audio EXIF. You can record directly to the GFX a digital voice message (mpg file) which automatically references the EXIF data in the image. LR can automatically visualize and play these audio files. So you can also listen to his own thoughts - in addition to the technical data - to the RAW file. Unfortunately, C1P can not (yet).
    For IQ3 / IQ4 I mostly take photos with a GRIII which I put together with the Phase One RAW files in C1P.
    Greeting Gerd
    Jan 2019
    29
    thanks a lot to all of you for all your valuable tipps. Its a pity that Phase One doesn't support Exif Data on the Back to Enter Lens and Shift Data... This should be very easy to do. It works with the XT, so the fields should be there... Just the option to enter them.
    I opted at the moment of taking a picture of the camera with the scene and shift value and lens with my iPhone.
    I guess fastest and easiest method... until Denmark moves...
    Frank
    Jan 2012
    www.benhuggler.com
    90
    Quote Originally Posted by eisbaer View Post
    Frank
    I don't think P1 will make this possible. They want this advantage only for XT users...
    Sep 2017
    on a mountain
    88
    4
    What I think at the time ....
    In C1 20, the tab Shift is currently missing from the lens corrections. Well it's a beta, but if you think evil, you might suspect that only XT cameras can use the fixes.
    Greeting Gerd
  19. #19
    Vancouver, WA
    6,460
    627
    It totally sucks. You should be able to use the IQ UI to enter the lens / aperture and shift values. It's not like it's hard to do compared to say frame averaging ...
  20. #20
    Oct 2017
    Berlin
    131
    8
    Hi everyone,
    regarding this theme, does anybody know whether there are dedicated/standard image metadata (EXIF, ...) fields for storing shift and tilt values?
    Where does P1 and the XT camera store such kind of info? Which fields does C1 read to get those values from the image raw file?
    Thank you in advance.
    Marco Ristuccia
