Results 1 to 4 of 4
Thread: Getting a 120 macro set up for product work
    Sep 2009
    Ontario, Canada
    466
    I have a Rodenstock 120 apo macro sironar in a Copal 0, and use it for images up to about 1:1. Mounted on an AS Monolith, it's a superb lens but I am really missing an electronic shutter for this application. I do have a spare Rollei shutter lying around so I could get th is lens mounted into it. Or I could just look for a lens already in an e-shutter and sell this one.
    Anyone know who can properly mount my lens into the Rollei e-shutter? I last had this done a long time ago and I seem to recall it was expensive.
    Jul 2016
    394
    Re: Getting a 120 macro set up for product work
    A rollei E Shutter is the same as mounting a copal 0.
    Jan 2012
    www.benhuggler.com
    90
    I changed all my Cambo Ultima lenses (SK 80, Rodie 55, Rodie 90, Rodie 120 Macro) from Copal to Schneider Electronic Shutter with no problems.
    There can be problems if the copal is shorter or longer than the E-shutter.
    Normally both are identical. Try it out, it is easy.
    You can't calibrate the F-Stops of the Schneider Shutter on your own.
    So you have to use an F5.6 shutter with an F5.6 lens or you have to work with other numbers....
    I bought a used Schneider Shutter but didn't know the max F-Stop . I normally work with F11. So I only had to compare the opening from the Copal with
    the opening of the E-Shutter to find where F11 is. Now I know with this lens F11 is showed as F16 on the shutter remote control.
    I don't know if you can calibrate the F-Stops of the Rollei Shutter on your own...
    Sep 2009
    Ontario, Canada
    466
    Thanks for the replies. I ended up just swapping the lens into the Rollei shutter and that seems to work just fine. I suppose I could send it to Rodenstock to have the element spacing optimized, but I don't see any issues with the lens as it is now. I originally came in this same Rollei shutter and is happy to go home.
