capture one 20 arrow keys don't work anymore
Boinger
I used to use arrow keys with C12 up and down to make adjustments on the various sliders.
That doesn't seem to work anymore with C20.
Anyone know how to fix this issue?
Gerd
It seems as if the controller values can only be controlled with the mouse, or by directly entering the values via the keyboard.
Even the mouse wheel for very delicate emotional adjustment is no longer possible. But that was already in the beta so, I was hoping that they fix it in the full version
Greeting Gerd
Boinger
Greeting Gerd
Yea I noticed the mouse wheel isn't working either.
This is very annoying I used to use those quite a lot.
cly
After having clicked into the respective field, I can use the arrow keys to adjust the values. (That's on macOS 10.14.6)
Chris
Gerd
I found out why the problem with the mouse wheel exists.
The scrollable toolbars prevent you from using the mouse wheel as usual. But if you press the ALT key while doing so, you can use the mouse wheel as usual to sensitively adjust the controller values.
Greeting Gerd
rjp85
Greeting Gerd
You just solved my biggest complaint of C1 20. Thanks!
