Results 1 to 8 of 8
Thread: Arca Swiss Cube Issues
    New Member lamoreauxphoto's Avatar
    Dec 2019
    Los Angeles, CA
    19
    Does anyone with the classic Arca Swiss ever unscrewed the knob that tightens to the plate to where it popped off exposing 2 springs and the threaded screw? I put it back on however the knob seems to wobble quite a bite when not tightened down. Doesnt seem right. Going to send it to Rod however before I'm without it for a few days curious if anyone had this issue and knows how to fix it?
    kdphotography's Avatar
    Aug 2008
    Carmel/Tucson
    2,824
    Re: Arca Swiss Cube Issues
    The "exploding" AS top clamp?
    Yes---that can be upsetting, but it's really not difficult to fix on your own---as long as you recovered all the bits and pieces that may have scattered across the floor
    Rod has a nice instruction sheet/pdf on adjusting the AS Cube top clamp.
    You can download them from my Dropbox here: https://www.dropbox.com/sh/rx1n1e3sb...m_kRDYL5a?dl=0
    ken
    Dec 2019
    Los Angeles, CA
    19
    ken
    Thanks Ken,
    I dont have the flip lock type though I have the screw thumb screw type (classic) -- I re-installed it but it seems there is a little brass color sleve that covers the threads on the screw that prevents the threads from screwing more into the base of the clamp and causes the wobbling I gather. hard to explain but it doesnt seem right.
    Aug 2008
    Carmel/Tucson
    2,824
    Bummer. A call to Rod and/or Precision Camera should fix things.
    Apr 2016
    490
    When I first received my Cube the screw clamp was binding up a bit and making some noises. I got in contact with Rod who warned me that the clamp might be defective and there was a possibility that it could "explode" without warning, which obviously would be a disaster if there were a camera in the clamp. He directed me to Bob Watkins at Precision Camera who fixed it under warranty. Even better, I took the opportunity to have him swap out the A/S clamp for a Really Right Stuff lever clamp and was only charged for the cost of the clamp. Turn-around was quick so all things considered it was pretty painless.
    Good luck!
    John
    Senior Member JoelM's Avatar
    Jun 2011
    San Diego, CA USA
    596
    A "trick" I employ when working on things with springs, or any situation where there is stored potential energy, is to work inside a large ziplock bag. If needed, you can work inside a trash bin bag as well if more room is needed. I've saved a lot of cuss words from their usage over the years this way. After waiting 2 months for a lost spring from a Swiss target pistol has taught me this life lesson.
    Joel
    Member Mexecutioner's Avatar
    Sep 2018
    Los Angeles, CA
    181
    Quote Originally Posted by JoelM View Post
    Joel
    That's not a bad idea and a funny story, reminds me of a deep mark in my dining room ceiling from a barrel bushing propelled by a recoil spring from a careless routine 1911 cleanup.
    Jun 2019
    Norway
    Not sure if you did this, but you need to remove the small plastic cover inside the screw knob and use a hex key to tigthen the bolt: You can remove the plastic cover by first tigthening the screw knob all the way in, and then gently pry it out using a small flat screwdriver or similar (that's how I did mine, note that it might leave a small mark in the plastic cover), It should pop out fairly easily. Once you have done this, loosen the screw knob back all the way out, and use the appropriate hex key to tighten the bolt to the clamp. If it came loose on its own it would probably be a good idea to add some loctite on the short end that screws into the clamp body so it doesn't happen again.
