The thing is that the rear end of the lens is 44.3mm in length. When it's focused at infinity on my setup, distance (j) is 30.15mm. It won't come anything close to infinity on my camera unless the rear end is 14.15mm past the camera board (d), which puts it inside my camera. That would work if the rear lens barrel was narrow, but it's not; diameter is 56mm.
The widest tech camera lens I could get on this thing was the Grandagon 55/4. It was 3.75mm past the face of the camera board (so inside), but the rear barrel was only 27.5mm in diameter, so I could shift it a tiny bit. Unfortunately, the lens cast problem made it not worth the bother.
I sincerely hope your camera has a design that allows lenses like this to work for you. I'm out of luck.
