Hello,
Has anyone experienced x sync speed problems between digital back and sekor Z lenses? I recently purchased the Leaf Credo and HX-701 adapter plate thanks to Andy-anlerman from forum. The problem I am having is that sekor 110mm lens with the sync speed above 1/250 is not recognized properly. 1/250 is recognized as 1/350, and 1/250 as 1/500 . On my second sekor 50mm anything above 1/125 is already indicating as higher shutter speed. Obviously photos are underexposed... I have also sekor 127mm and this one is a bit better as it jumps to 1/500 only at 1/400. Anything below is synced correctly. I am using multipin (8-pin) cable from Leaf Credo to the sekor z lens. Camera and lens contacts are clean.
Does it mean that the lenses are defective ? I got both lenses recently from RobertsCamera so I believe this can be repaired ??
Any thoughts or suggestions?
Adam
Adam
