Received. What do you think of the raws?
Thanks for providing the raws.
I played around with the Harbor Sunset and Promenade Underexposed raw files and noticed that the DualExposure+ files have lots of little blending/masking artifacts.
On the Sunset image the darkest area seems to be under the pier near the bottom right corner. When pushed hard (+100 Black and +100 Shadows, no exposure push) the sensor banding shows up even in the DualExposure+. And in that particular area there are some noisy blobs where it seems the software chose to blend in parts from the darker exposure.
On the Harbor image for some reason I cannot find any banding in the single exposure while there is some banding in the DualExposure+ file when you look at the deep shadows under the pier. Again, that area has lots of blending artifacts where parts of noisy texture from the darker exposure are blended onto the smoother texture of the brighter exposure. Near the bottom left corner there is a jogger in pink. Based on her running direction I’d say the DualExposure+ process starts with the longer exposure and finishes with the shorter exposure. You can see a pinkish trail from the longer exposure behind her which feels more natural than the other way around. But still, the way moving objects are blended in from the shorter exposure feels like bad retouching because of the difference in texture. If the individual exposures of the DualExposure+ files could be processed with different noise reduction settings maybe the differences in texture can be smoothed out.
While DualExposure+ surely is a promising tool, in the current Capture One processing the user has to examine the file very carefully for artifacts. It would be great if Phase One allows the user to fine tune the automatic blending/masking suggestion in Capture One. I’m aware the feature is still in beta. Let’s see where they take it.
I really welcome the Lab approach. Hopefully, this will open a dialogue between the Phase One R&D team and Phase One users.
-Dominique
