Ziya--
I run a WRS1000, IQ4150, and have the WRE-CA (which gets more use than I thought it would when I bought it; I shoot architecture). I'm planning to write an article soon, having tested all but one of the current TS-E lenses on the WRE-CA.
If you have a WRS tech cam already, you don't/shouldn't need the M645 adapter (but if you can't mount your IQ4150 to your WRS, you'll need an adapter plate for that; talk to your dealer). The WRE-CA mounts in place of your normal tech camera lenses, so what you end up with is the IQ4150 -> WRS -> WRE-CA -> your Canon glass.
What I've found:
1. All* current TS-E lenses work (*: I've tested everything except the 90, which Canon CPS didn't have in stock for tryout; I'd expect it should behave just fine though). The 17 and 24 have enough coverage to give you a couple mm or so of usable movements; there is noticeable blur along the edge of the image circle in some cases. The 24 benefits from LCC somewhat; for the rest it doesn't matter much. The longer TS-E's vignette, but if you crop, you still get about 100 effective MP of extremely usable image data. You can also use the tilt mechanism on the TS-E's, so if you're in a situation to need/want Scheimpflüg adjustments or tilt blur, you get those options.
2. I wouldn't attempt to use the older TS-E's in this setup; the TS-E 24 MkI and 48 MkI from the early 00's had scarcely enough resolution to give decent results on a 10MP DSLR on a good day; I'd expect them to be a complete waste on an IQ4150.
3. You are limited to electronic shutter only in this configuration. If you're doing something where that's not an issue (landscape, architecture, product where you can drag the shutter if you're firing flashes), that's not a big deal.
Dear All,
I hope all of you are in good health under these unfortunate circumstances.
As most of us, I am self-quarantined at home in Istanbul.
As an owner of IQ 4150 with Cambo WRS and XF, my XF lenses almost always sit idle aside of Rodenstocks.
Also I have Canon TSE lenses from old days. So I consider getting both Cambo WRS M645 and WRS-CA to use all my lenses with WRS.
I would really wellcome if any of you had an experience with these items.
My best wishes go to you all and please stay home to keep away.
Stay healthy.
Ziya
