Lets try Step by Step.
There is a Trace connecting the two Resistors (black with "224" and 393") on right f the IC. To which Pin of the IC is it connected?
Is one of the Pads of the soldered off Part connected to the Metal of the connecting Jack? (left down Corner of the first Photo.
The lower Pad of the soldered off Part has a small Trace ending in a "Hole" - that is called Via. Try to find out to which Pin of other Part it is connected.
The upper Pad has a Trace going under the IC. To which Pin of the IC is it connected?
For easier conversation:
Zhe IC has a Marking in the lower left Corner. That Pin is "1". Counting to the Right is 2,3,4 and 5. Pin in upper Right Corner is "6" counting up to the Right 7, 8, 9, 10
