Phase One P45+ Body Choices
felix5616
I am close to purchasing a phase one P45+ back. As i already own a mamiya 645AFD(I) body and lenses what advantages/disadvantages are there between a mamiya 645 AFD and Hasselblad H system? I am looking for feedback from anyone that ghas used there bodies with the P45+ back. I do not shoot professionally and shoot mostly landscapes, rare portraits, and macro.
Guy Mancuso
Administrator, Instructor
Depends really if you need a leaf shutter or not and sounds like you do not than I would go with the Mamiya myself since you already own one . Mamiya lenses will be smaller and lighter because of no leaf shutter and typically cheaper depending on what lens and speed it has. There both very good systems . For the Hassy will need a H2 for the Phase back and I think the H2F will take a 28mm lens but a Hassy shooter can confirm that for sure. I would if you can play with both Camera bodies and see what you like before you buy the back since you have to chose a mount for it. A lot of this comes down to personal preference also and feels good in your hand and the system behind the body. Some will like the Hassy better and frankly there is no right or wrong here. Either way you still have the Phase back and C1 to work with so no changes there and C1 will see the Hassy glass for lens corrections with a Phase back. I personally went the Mamiya route and don't regret it and will most likely continue with it for a long time. For me that is a major commitment.
There is a P45+ and hassy for sale in the B&S right now also you may want to consider if Hassy is the way you want to go.
fotografz
There is a hardly used Hassey H2 and P45+ with 2 years of warranty left for sale in the F/S section here. It's listed by Lance, a Phase Dealer rep for a customer of his I think, so the source is a good one.
The main difference between the two cameras is that the Mamiya is a focal plane camera and the H cameras are leaf shutter.
I have owned and use both and stayed with the H system because I use strobes in studio and fill flash outdoors thus needed the higher 1/800th sync speed verses the Mamiya's max 1/125th sync.
Depends on your specific needs.
Guy Mancuso
I noticed and we both said essentially the same thing and this comes from two Pro's that in reality think almost the same things but we both shoot different systems and for different reasons. There is no right or wrong just preferences
felix5616
i have already communicated about the P45+ and hassy kit. One reason i am leaning to mamiya is that i am taking delivery on a pentax 67 to mamiya adapter so i can use my pentax67 100mm macro lens and my pentax 67 bellows for 3x macro work (pentax 67 bellows, mamiya 645 body and P45+) with the P45+,i am excited about that possible combo. I also don't want to add to my already large collection of camera bodies. I have a ZD camera that i am trying to sell. I am impressed with the quality and naturally wanted to go a step further in terms MP count and long exposures.
kdphotography
How heavily invested are you in Mamiya glass? If you already have the platform with lotsa glass---then I think you would be better off with getting a MFDB with that platform. You can always change platforms and switch the Phase back later.....particularly since you'll probably want to upgrade your camera body eventually...
dougpeterson
I agree with Guy; the task of deciding between bodies should start with leaf vs. focal plane shutter. Both bodies are exceptional tools and each has niches where its advantages make it the better choice.
Landscape
Using a leaf shutter lens (the H body) for landscape you will suffer (extra weight, size, cost - slow max shutter speed) without benefit (high flash-sync-speed doesn't ).
Portraits
Portraits taken without flash or studio portraits are largely the same between the two bodies. Portraits taken on sunny days outdoors with flash favor the leaf-shutter in the H-body IF you want to make the flash the primary light source and not just fill.
Macro
The Mamiya/Phase and Hasselblad Macro lenses are both absolutely stellar; however, there are two bellows systems for the Mamiya/Phase if you ever want to go past 1:1. I don't think (correction anyone?) that the Hasselblad system has any bellows system (leaf shutter lenses make such systems more difficult).
Usually I would list the dozens of pros/cons of each body, but if you're shooting mostly landscape and already have/like the Mamiya body then I wouldn't look much further. In the future you might upgrade to a more recent version of the AFD body, but most of the improvements don't apply to landscape photography. You might also consider a technical body which is dedicated to landscape photography; they are harder to use (generally speaking) but produce unquestionably the highest image quality available when using the latest large format lenses.
Doug Peterson (e-mail Me)
__________________
Phase One, Canon, Apple, Profoto, Eizo & More
National: 877.217.9870 | Cell: 740.707.2183
Newsletter: Read Latest or Sign Up
Sr. Administrator
Staff member
I'll agree with everything that's been said already and just add one small point: That it is easy to adapt third-party lenses and accessories to focal-plan shuttered bodies, but virtually impossible to adapt them to leaf-shutter bodies. So here, with your current stable of Mamiya and Pentax glass and bellows, the Mamiya body sounds like the most logical choice...
eleanorbrown
I use an H2 with my 45+ and it will NOT take the new H28mm lens to my knowledge. anyone correct me if I'm wrong but think the new 28 lens only works with the newer H3 models. I love my H2 but they are hard to come by as they have been discontinued. Eleanor
Guy Mancuso
Thanks Eleanor but I think the F model will. Maybe David can chime is to confirm this. I remember on a workshop Joe Ramos heard from Hassy that he could use it. But let's confirm this up for sure.
Digitalcameraman
It has been confirm by Phase One that the new H2F will not work with a Phase One back. There was a lot of rumors that this combination should work when the H2 was discontinued overnight. I am still a huge H2 fan and we continue to supply customer with H1/H2 bodies and Phase One backs. This will not change.
It is a real shame that platform was short lived and no one at Hasselblad felt their was a need to support the 28mm lens.
H2 F for Film, right.
Chris Snipes
Image Production, Inc
Phase One Reseller
Phase One Test Studio
www.imageproduction.com
[email protected]
eleanorbrown
Guy,yes you are correct, it can be used on the F model....but can you use a Phase digital back with the F model? Maybe with cables, etc?? don't know. I go waaay back with Hasselblad, as I do with Phase....I'm sorry to see Hasselblad had d/c-ed the H2, thus cutting out Phase as we all know...sigh.....Eleanor
ptomsu
It is not even true if the H3D2 with their future 60MP back will be able to support the 28 lens as it currently exists. Definitely NOT without even more SW correction (vignetting, edge sharpening and distortion correction) as for their 50 and 39MP backs.
On the Phase/Mamiya the 28 works also for fil backs - NO SW correction here :thumbup:
I call this really open, future proof and great!
If I would buy a P45+ back my decision would be clear - go with a Phase/Mamiya camera and lenses ;)
Digitalcameraman
The talk prior to the release of the H2 F model was that you could use a Phase One H mounted back and a sync cable like we do on the Hasselblad V system. We waited to hear from support if this was true because the H2F was suppose to support the 28mm which was never supported when using a H1/H2 with Phase One backs.
Listed below is the offical word from P1 and the use of their backs on the
H2 F. Now I really know why they called it a H2 F. Use your imagination.
Chris Snipes
Phase One Reseller
[email protected]
Using a sync cable from the body was Hasselblad's original claim of how the H2f (back when they said the f stood for film) would work with 3rd party backs. Of course many things changed since that first announcement. Hasselblad went back on their announcement, did a 180 and instead of building a simplified body, they merely upgraded the firmware of the H2 to block 3rd party backs, and allow more integration with Hasselblad backs.
In other words, even though they once said a sync cable will work... it will not.
_________________
Kind Regards,
Jon Gilbert
Phase One
ptomsu
Chris Snipes
Phase One Reseller
[email protected]
_________________
Kind Regards,
Jon Gilbert
Phase One
And BTW - just be happy it does not work, because I think a sync cable is not really a great solution :D:cool:
Ben Rubinstein
Naughty Hasselblad. They're pretty serious about closing the system.
As far as focal plane goes, for landscape, I was shooting today at midday middle east full blown sun, getting a 1/50th f22 @ iso 100 which is pretty much exactly what it should have been given 'sunny f16'. If you're shooting landscape with medium format you are stopping down and given the iso properties of these backs, using a lower iso. It's probably unlikely that a landscape shooter with a MFDB is going to sweat a max 1/500 or 1/800 shutter speed. Commercial is another kettle of fish. So is lugging heavy leaf shutter lenses in your bag.
fotografz
Chris Snipes
Phase One Reseller
[email protected]
"H2 F for Film, right."
Not quite correct ... actually, not correct at all if the implication is that the H2F camera is only a film camera.
The H2F accepts all current and former Hasselblad CF, CF-II and CFH, single and multi-shot digital backs as well as H film backs ... while providing access to the DAC corrections, where the H2 does not. The H2F supports all of the HC lenses when using any of the backs mentioned, including the 28mm.
The difference is the firmware in the camera and the digital back ... which is upgraded through the Phocus software. It's all part of the integrated philosophy of one cohesive system between body, back, lens and software, and the ability to add system components like the HTS and new zoom with DAC programed in via continuous firmware and software upgrades.
