If I buy a hard drive from any dealer I regularly visit, I can return ir for an immediate replacement or refund if defective.
Yes, I can go test drive a Canon 600mm f4 IS lens right now at my local dealer that is less than a 15 minute drive for me.
I can even go test drive a Tessla in less than 20 minutes. The Vanquish I'd love to own is more like a one hour drive away, and I can drive virtually any Ferrari I might consider if I take a one-hour flight.
So yeah, I'd expect to be able to demo or "test drive" ANY camera I was seriously thinking about buying...
Don, sorry, honestly... you walk through the landscape place your camera anywhere, imagine a rough picture of what you will get, take a shot and check it on the LCD (on the LCD of the P45+ notabene). Afterwards you crop what you like.I really thought I "needed" a viewfinder and sliding back to do "proper" photography - ended up not needing either.
once I do a spot check on the LCD I'll know I either have it or need to add another image for additional movement (I don't move the camera rather I add whatever additional amount of movements I feel is necessary and correct in post).
Sliding back is the other item that was on my original must have list. Sure it looks good but does it "fit my workflow need"? The answer quickly came up no. Let's face it there simply isn't a decent groundglass available for MF.
so you cropped the most interessting partAt the time I was relegated to working off my small laptop so to make the file more manageable I cropped off the sides...
Jack,Okay, I take back disingenuous and maybe give you unrealistic instead. In every category you care to mention there are items that a dealer doesn't stock, because they are special. Not only expensive items. I mean, you don't take hard drives out for a test drive either, right? And where can you test-drive a Canon 600mm f/4? And there are cars you can't test drive, at the top end. The arTec is no different. Don't expect to find one at your dealers. On the other hand, Tom was able to ask Sinar directly for a test drive, and IIRC got one shipped to him for a few days. I don't know what Arca does.
It's slightly more complicated that what you said in the first couple sentences.Don, sorry, honestly... you walk through the landscape place your camera anywhere, imagine a rough picture of what you will get, take a shot and check it on the LCD (on the LCD of the P45+ notabene). Afterwards you crop what you like.
That's nice and that's doable but it's certainly not what I'd call composition.
Do you know the ammount of shift in millimeters and what it means to sharpness fall off by estimation? No, not if you don't use the groundglass where you can see the movements in millimeters. The sliding back and groundglass are not only to focus, these are great tools for compostion. I fight for millimeters... i.e. move the tripod a meter forward... another half meter forward... another 20cm forward... all the time checking lateral and vertical movements.
It's okay that you don't compose with the camera but instead with the computer... but that's not a well balanced reason to discard tools like finders, groundglasses, sliding backs (and if you would work with groundglass for composition - rather than focussing - you would understand the value of a sliding back).
Again, it's okay that you don't need these tools or don't want these tools. But there is a certain justification for each of these tools - no doubt!
I didn't refer to the sharpness fall off of a certain lens in general but the movements with regard to the composition. If you want to have a certain motif within a certain sharpness you can only see it on the GG. When I do stitching I capture a wider range as well but I know that I am going to cut the image at the point of, say, +/-15mm shift so that I am sure that the respective part of the motif is really sharp.Regarding knowing the amount of sharpness fall off per amount of movements - I know by the time I go out what the particular lens is capable of producing at a given f/stop and amount of movement so there's little guesswork involved.
Be that is may. If it makes sense to him that's okay - no objection here.from what i have seen by Don, whatever method he is using is producing some outstanding images. He certainly doesn't need a lecture on the methods of composition.
