Results 1 to 3 of 3
Thread: Shortest lens: Rollei x-Act2 with Nikon D3?
    HOG2001
    I use a Rollei x-Act2 in combination with Nikon D3 and Schneider Componon-S 150mm. Now I want a shorter lens...what is the shortest usable lens having room for shifting? Any experiences?
    Roman
    Jan 2010
    156
    Re: Shortest lens: Rollei x-Act2 with Nikon D3?
    Quote Originally Posted by HOG2001 View Post
    Roman
    I have tried it with a Canon and a 80mm Digitar on the regular lens board and it did not work. After checking the focus I calculated that you will need at least a 100mm and wide angle bellows to get infinty focus, and some movement possibility (no warranty). Rollei's recessed lens board would also help a little to get the lens closer to the camera.
    However, I found 100mm is too long for my needs, so I made my own lens board with 40mm of recession. Now I can get the rear element of the lens directly in front the mirror box., and still have plenty of movement.
    However, for this modification you will need the cambo type of digitars, cause they do only have the aperture ring and no shutter. (Schneider and Rollei shutters are too big to allow deep recession).
    HOG2001
    Interesting...thanks for the reply, and the advice.
