Results 1 to 6 of 6
Thread: Ricoh GXR - Removing the "target focus shift" icon
    Member bcf's Avatar
    Jan 2008
    Lyon, France
    125
    Using the GXR, when I press the ADJ lever, a row of 5 icons appears, the first 4 of which I can assign in the "Key Custom Options" menu. The 5th icon corresponds to a "target focus shift" function, which I absolutely never use, but very often select by accident. Is there any way to remove this 5th icon from the screen - I could not find one.
    -- Bernard
    Member bcf's Avatar
    Jan 2008
    Lyon, France
    125
    Re: Ricoh GXR - Removing the "target focus shift" icon
    Apparently nobody is troubled by that, or nobody knows the answer, or my explanation wasn't clear…*:-)
    -- Bernard
    Jan 2008
    Toronto, Canada
    3,026
    1117
    I have the same behavior and didn't see a way to fix it.
    Keith
    Member bcf's Avatar
    Jan 2008
    Lyon, France
    125
    Keith, thanks for your reply.
    -- Bernard
    Godfrey's Avatar
    Jan 2009
    Near San Jose, California
    7,927
    No way to change this setting far as I'm aware.
    (I had not used it before, but then I was doing some macro work with the A12 50 camera unit, camera on a copystand. Being able to retarget where the AF spot was in the frame without moving the camera or subject turned out to be invaluable.)
    Member bcf's Avatar
    Jan 2008
    Lyon, France
    125
    Thanks Godfrey.
    Yes, I realize that this setting may be useful, but it would be nice if its display was optional… For some reason, very often, when I want to change another setting for which I have chosen to display an icon in the EVF (triggered by the ADJ lever), it is the "target focus shift" icon which is selected when I press ADJ, although so far I have never used it (voluntarily, at least…
    -- Bernard
