Results 1 to 8 of 8
Thread: Ricoh GXR-Capturing Slides
    Godfrey's Avatar
    Jan 2009
    Near San Jose, California
    7,930
    I normally use a Nikon Coolscan V ED to capture slides, but I thought, "hmm, I wonder how good the GXR A12 50 Macro is for this. So I did a test, and through in the Micro-Nikkor 55/3.5 as well for comparison sake.
    Report here:
    https://dl.dropbox.com/u/25268645/sl...ure/index.html
    In the end, the scanner does the best job, most easily, but the GXR acquitted itself nicely too.
    Comments?
    Godfrey - GDGPhoto Flickr Stream
    Member Agnius's Avatar
    Apr 2010
    Santa Monica, California
    135
    Re: Ricoh GXR-Capturing Slides
    Godfrey,
    Not too bad. I still prefer the coolscan image though. I wonder if by masking the unused portion of the light table you could eliminate the green band on the nikkor image (bottom of the robe).
    GXR macro shot is cleaner color wise.
    Good luck!
    Godfrey's Avatar
    Jan 2009
    7,930
    Quote Originally Posted by Agnius View Post
    Godfrey,
    Good luck!
    Thanks for looking.
    Yes, to do the copy-slide setup properly, I need a light shield between the slide and the lens for either lens. I didn't have time to make one for this quickie test.
    Curious that you feel the GXR macro shot is cleaner color-wise. Both GXR exposures (with A12 50mm or Micro-Nikkor 55mm) took a significant amount of tweaking to match the slide original as best I could (in a half hour... ;-) while the film scanner and VueScan exposure required virtually no adjustment at all and is a darn close match to the original right out of the scanner.
    Apr 2010
    135
    Thanks for looking.
    I feel the color band using Nikkor was more disturbing than uniformity of Ricoh macro, but who knows what caused it. Yeah, don't retire your scanner yet.
    Godfrey's Avatar
    Jan 2009
    7,930
    Oh, that's easy: sloppy work on my part. :-/
    It's a reflection of the room lamp off the top of the slide. Note in the setup photos that the much longer focal length Nikkor (55 vs 33 mm) provides several more inches of working room, allowing more of the room lamp to reflect on that exposure. Both exposures with the GXR should have had a light blocking shade surrounding the lens and the slide to prevent that happening. Just didn't have time to rig one up. :-)
    Jan 2008
    Toronto, Canada
    3,026
    1117
    "Old and New"
    A16
    Keith
    Godfrey's Avatar
    Jan 2009
    7,930
    This is nice, Keith, but what does it have to do with capturing slides?
    Jan 2008
    Toronto, Canada
    3,026
    1117
    Godfrey, it's the only way for me to get people to look at my stuff
    Sorry about that!
    Keith
