Results 1 to 8 of 8
Thread: Processing DPxM files
    Apr 2008
    134
    57
    This may be of interest to some here.
    I found a link to a site run by Martin Zimelka (www.martinzimelka.com) which has an interesting review of the DP2M. He also has an interesting procedure for processing in SPP which never occurred to me before.
    I have often been frustrated by images that require the exposure to be reduced to avoid clipping of highlights and then using Fill Light to bring up shadows. A kind of "faux HDR" look can result.
    His tip is to save a colour image out of SPP and at the same time a copy with the WB set to monochrome. Open both as layers in Photoshop with the colour image as the top layer and change its blending mode to "colour".
    Playing around with some problem images this does look very promising. Of course it hugely increases the workflow but even with this method I can process files much quicker than making a print in the darkroom from a difficult negative. Might be worth look at. Here is the link.
    First Impressions
    Jan 2013
    North of Copenhagen, Denmark
    117
    Re: Processing DPxM files
    Thank you for this link
    Feb 2013
    78
    That is a great thing! Also makes the rendering of skin muuuch better. Doesnt enhance every little color-difference as it does normally
    Jun 2013
    415
    Excuse my ignorance, but what means set WB to monochrome?
    Tubac, Arizona
    139
    Thanks for this link! Very interesting read.
    Lawrence
    Feb 2013
    78
    Quote Originally Posted by foveon View Post
    There are two ways in spp to make a black and white image. The old way is setting the white-balance setting to "monochrome" which was not really pleasing, cause it was noisy and so... And then they made the monochrome-menu on top of the menu, that works better.
    so wb monochrome is a wb in color-mode, that makes the image black and white.
    Jun 2013
    415
    thanks
    Mar 2014
    556
    pflower...
    When I read this article time ago I thought I would never care. Have no DPs, so why care.. ;-) Now I will soon have and now I care, but forgot about the article.
    Thanks for bringing it up to the surface again.
