Results 1 to 6 of 6
Thread: Sigma Merrills and IR
    Jun 2014
    9
    Anyone have any hands on experience with IR on the Merrills? If so, what nanometer filter did you use?
    Feb 2013
    78
    Re: Sigma Merrills and IR
    I think it will not work well until you remove the ir-cut filter. dpMerrill are not exactly built for longer exposure...
    Nov 2009
    27
    I tried a standard Hoya R72 filter on the un-modified DP2m and DP3m a while back, and the results didn't encourage me to bother again! It might be better with the low-pass filter removed, but I'm not going to sacrifice one of mine to try it.
    Jun 2014
    9
    Well, the R72 is too much for a Sony A77 too.
    Nov 2009
    27
    Just tried a couple of tests with a weaker filter - not sure of the exact wavelength but it's a Leica 39mm IR filter which works nicely on my M8
    On the Sigma DP2m there's both a pronounced hot-spot in the centre of the frame, and a very weak response to the IR waveband, so it doesn't look workable without removing the low-pass filter.
    Jan 2015
    Bellville, TX, USA
    109
    Quote Originally Posted by dbarthel View Post
    Not Merrill, but I've used the SD10 with it's "dust-cover" removed. I bought a variety of filters and settled on the Marumi 700nm as best for my purposes. The AF works with that filter on. Some higher nm's do not, leaving you with focusing with the filter off
    If you don't own a SD1 or SD1M, I wouldn't even bother! A cheap SD10, SD14 or SD15 would be much better as your dedicated UV/full/IR camera. Not the SD9 though - it's hot mirror is epoxied onto the sensor, almost impossible to remove.
    Ted
