Have I understood you correctly? Did you mount the Leica lens on the SD14? If so, How did you do that? Is there an adapter available?Ok, I finally got some sleep and took the first test image of the SD14 at ISO 50 with the Leica Apo-Summicron-R 2.0/180. The noise is extremely well control with this first sample and the color seems accurate for AWB. I need to work on the resolution next. More test to come later. The Leica Apo-Summicron-R 2.0/180 was shot at F2.0.
Rob,I just took a look at the Sigma SD14 site. It took a lot of digging to find the specs.
How big are the files from it? How do the files look now that you have had a chance to shoot with it a bit?
Robert
Robert,How are you doing the shifts with the Leica lens? I assume you loose infinity with your shift adapter.
Ah... I see. That's good to knowJorgen, meet Son... Son has custom adapters to mount almost anything to almost everything else
