Results 1 to 13 of 13
Thread: Printing on 17X25 Harman with Epson 3880 - Help!
    jonoslack's Avatar
    East Anglia & Cornwall (UK)
    11,778
    Hi There
    I just received my 3880 yesterday (the 4000 has finally gone into retirement).
    I've been experimenting with Harman gloss paper (love it). However, I seem to be incapable of printing to 17"x25"
    It doesn't exist in the default paper sizes - I've managed to make a custom size up, which I can easily pick in Photoshop, or in Aperture 3 - however, when you get to the last stage (with the epson driver showing up) It looks like it's going to do the right thing, but if you look under paper handling (in summary) it says:
    Destination paper size: Document Paper A4
    and if you make the mistake of pressing the print button . . . . it prints an A4 sized image in the bottom right of the sheet!
    I'm sure I'm missing something here . . . can anyone help please?
    all the best
    Just this guy you know
    Terry's Avatar
    New York City
    6,955
    1145
    Re: Printing on 17X25 Harman with Epson 3880 - Help!
    IRRC - we had this same thing come up when we were in Carmel. I know Jack has the answer (which if my pea brain can remember had to do with reversing the measurements).
    edit - or Bob
    Administrator Bob's Avatar
    Prescott, Arizona
    4,492
    367
    Jono,
    Did you create/select the custom paper size in the epson driver as well?
    Is this on a mac?
    thanks
    -bob
    1,860
    Assuming the 3880 is basically same (driver wise) to 3800, I do print to 17 x 25 often and think Bob has the answer. I use Lightroom, make a custom size there but have to also create it in the Epson driver as well. I'm on a PC though.
    jonoslack's Avatar
    11,778
    Hi There
    Bob - Diane thanks for the input.
    Yes - I've made the custom size in the driver (I did it in pages) (I couldn't do it from aperture as there is no 'page setup' option) - I did it in another application, and it does show up as a size within Aperture - it's the printing bit that buggers it up.
    Of course, I'm using Snow Leopard, so I guess things will be different.
    Aaaaahhhhhh! Got it (thank you Terry for your hint).
    When making the custom setup you must treat it as portrait, which means that you set it up as width: 17 Height: 25. I can't try it right now as the printer isn't here - but it's now showing correctly in the summary.
    Hooray (as long as it works!)
    1,860
    I think I had to do the same in my driver AIR and I think I just found it more or less by fiddling with it. Strange, no???? LOL
    jonoslack's Avatar
    11,778
    Quote Originally Posted by Diane B View Post
    It's a bit odd . . . and rather costly experimenting with 17x25 sheets of Harman!
    Let's hope it actually does work when I get home
    Subscriber Member weinschela's Avatar
    New York suburb
    458
    I was informed yesterday that Harman has discontinued 17 x 25 FB gloss. It has been my favorite. Anyone know of other good 17x25 gloss papers? I really don't want to buy a roll and cut (Epson 38xx series has no roll feed).
    Diamond Star Halo
    Thanks everyone for this post of 2 years ago because it helped me out tremendously now. I had the exact same issue as Jonoslack.
    Perhaps you can help me with a related issue Im unable to print using the Epson 3880s Rear Feed Slot.
    I originally printed through the 3880's Auto Feed Slot and it came out fine except there were some faint roller marks on the print.
    So I'm trying the Rear Feed Slot to avoid the roller marks. But I keep getting "Incorrect Paper Source Setting - make sure the loaded paper and the printer driver settings match."
    I didn't change any of the settings, which worked fine when I fed the print through the Auto Feed Slot. And I followed the manual's steps for inserting the paper into the Rear Feed Slot.
    Any suggestions?
    Perhaps I have to adjust the platen gap (Manual at page 40)? Im using the same 17 x 25 Harmon Gloss paper that Jonoslack used.
    Member Greg Lockrey's Avatar
    Temperance, MI
    141
    Quote Originally Posted by Diamond Star Halo View Post
    Perhaps you can help me with a related issue – I’m unable to print using the Epson 3880’s Rear Feed Slot.
    Any suggestions?
    Perhaps I have to adjust the platen gap (Manual at page 40)? I’m using the same 17” x 25” Harmon Gloss paper that Jonoslack used.
    The rear slot is for "heavy" paper.... at least it's that way on my 3800.
    Diamond Star Halo
    Thanks for the quick reply Greg. You're right that the rear slot is for heavy paper. I failed to select "Manual - Rear" in the "Source" setting. Since I was feeding a sheet, I erroneously had it set to "Sheet."
    In any event, I am still getting those roller marks on my 17 x 25 Harman Gloss paper --the marks are horizontal lines down the center of the image. When I tested with 11 x 14 Epson Glossy Premium, there were no marks at all.
    None of the following worked. I tried them all and I still keep getting those marks:
    1) I unchecked "High Speed" in the "Quality Options" menu thinking that the marks may not appear if the ink has a little more time to dry.
    2) I changed the platen size from "Standard" to "Wide" thinking the Harman paper is thicker than the Epson paper and, therefore, pressing against the rollers.
    3) I created a Custom Paper Configuration (Manual at page 41) with these settings:
    • Platen: “Standard” as Epson suggests
    • Thickness Pattern: 3 – but it was hard to know what to select. The lines that are printed are faint and small. So it is very difficult to see the gap between the lines to determine which setting number to select.
    • Paper Feed Adjust A and B: I made no settings because I'm not getting any banding.
    • Drying Time: I picked 10 seconds (so that there is plenty of time for the ink to dry).
    Again, none of these options worked. I could keep changing the variables in the hope of hitting the right combination. But each attempt wastes paper, ink and time.
    If anyone has successfully printed 17 x 25 Harman by Hahnemuhle Gloss Baryta paper on an Epson 3880, I would appreciate knowing the settings. Thanks everyone.
    Apr 2010
    Somerset - UK
    92
    I would suggest you go to the Harman web site and send them an email (or phone them). I would expect them to supply you with the correct settings, since I would hope they tested their products on various printers, and your printer is not exactly unusual. If you still get the marks, then you need to decide if the problem is with the printer, or that Harman did not conduct proper trials.
    Diamond Star Halo
    Thanks for your suggestion Ray -- I sent them a detailed email. I was leaving them as a last resort after pretty much exhausting the possibilities with the printer.
