Results 1 to 6 of 6
Thread: HELP with Epson R2880 printer
    415
    77
    I have had pretty good success with my new 2880 printer until now. I was printing several 13x19 prints for a swap and the photo black ran out in the middle of my 7th print. It was brand new! Also, when i took the cartridge out, it looked as tho' the cartridge was starting to leak ink. Is this the clogging that I have heard about and what do I do about it? Thanks. I really need to get the other prints done asap!
    Los Altos, CA
    10,486
    1031
    Re: HELP with Epson R2880 printer
    Hi Durr,
    I don't have that printer so cannot answer specifically, so hopefully somebody with more experience can comment. I did have a 2400 several years back, and from your description, I would say it sounds like a faulty cartridge. It could have been a clog, and then it leaked when you removed it because it still had ink, but I doubt it. The only other comment I can add is that I do recall my 2400's inks not lasting for very many 13x19 prints, but I also recall it not letting you print if a cartridge got too low on ink forcing you to replace it before proceeding.
    home: www.getdpi.com
    415
    77
    Hi Jack,
    Wouldn't you know that was my last photo black cartridge? I ordered some more ink last night and will see what happens. Thanks for your reply and advice.
    Durr
    Los Altos, CA
    10,486
    1031
    Quote Originally Posted by durrIII View Post
    Hi Jack,
    Of course -- that's the printing 'Murphy' at work!
    Oct 2008
    Hurst, Texas (DFW area)
    179
    Hi DurrIII
    The Epson 2880 cartridge ink capacity is only about 11-12 ML. When I was running a 2200 (14 ML cartridge), I always kept a spare full set of cartridges so as not to run out in the middle of printing. It's the primary drawback of this particular printer. On the other hand, the image quality is really good with proper color management. Atlantic Exchange (ATLEX) has good prices on printing supplies and they do a good job of packing the paper.
    Paul
    415
    77
    Thanks Paul,
    I will check them out.
    Durr
