Results 1 to 7 of 7
Thread: Epson 9900 paper jams w/ Canson Platine Fiber rag
    Member 2jbourret's Avatar
    Jan 2011
    Ketchum, Idaho
    144
    I've had minimal trouble w/ paper jams since starting to use a new Epson 9900, but have had nothing but trouble with one paper, Canson Platine Fiber rag. I generally use Moab Entrada in sheets and roll, but I'm testing with Canson Baryta and Canson Platine Fiber rag sheets, both in 8.5/11 size. The Baryta runs fine, never a jam, but the Platine jams every time, not a single successful print yet. I am using each with the appropriate profile and Epson paper setting for each. The platine sheets seem to have more curl than the Baryta, so I've bumped up the suction a notch, but still no success.
    Any thoughts?
    Reykjavik, Iceland
    2,310
    9
    Re: Epson 9900 paper jams w/ Canson Platine Fiber rag
    I find that with papers that have a reverse curl (like Harman Gloss Baryta and similar), I need to bend the paper against the curl. I bend it both lengthwise and across the width. If it is very bad, I will curl the four corners back a bit as well. 8.5x11/A4 and 8x10 seem to suffer the most, as when the 9900 loads the paper, if the sheet is small it will go under lip of the paper intake, and then when it does it's back and forth paper loading dance, it will hit the inside edge of the printer and jam. It will not do it with larger papers, as they do not go below paper intake area, so they can't catch on the same place. (I am not sure if that is well described, but I could snap a photo if you are not sure what I mean). Basically though, after resorting to giving a bit of careful bending in the opposite direction, I have not had any paper types that I haven't been able to get to work. Also make sure you have the platen gap set to wide or wider...that should prevent head strikes or jams in papers that have reverse curl.
    My photos are here: http://www.stuartrichardson.com and more recent work here: http://stuartrichardson.tumblr.com/ Please have a look at my book!
    My lab is here: http://www.customphotolab.is and on facebook
    Member NotXorc's Avatar
    Jul 2010
    113
    That's a good word, Stuart.
    I use both of the papers mentioned, but have only had difficulty with the Gloss Baryta on my Epson 3880. Instead of jams, I experienced head strikes, usually as the 8.5 x 11" print was almost finished. Next time, I will orient the paper in landscape aspect and impart a reverse bend, to flatten out the curl. Cheers!
    Jan 2011
    Ketchum, Idaho
    144
    Although my problem is not yet solved, I am happy to report that I was contacted by a representative of Canson, who is working with me to find a solution. It is encouraging to find that there's a company that, simply based on a posting here, will take the initiative to seek to resolve a customer's issue w/ their product.
    I'll post results when the jury is back...
    Aug 2010
    Gainesville, Georgia
    177
    21
    Amen to that kind of support! Charles
    Jan 2011
    Ketchum, Idaho
    144
    OK, the jury is back, and the outcome is good. Turns out that lack of humidity in my locale (typically below 20%) causes the coated papers to warp as the inks are laid down, which in turns causes headstrikes and jamming. I've installed a humidifier (and humidistat), humidity in the print room is being maintained at 35-40%, and I'm now having no problems.
    Reykjavik, Iceland
    2,310
    9
    Very interesting...it is amazing how many minor variables can have a significant impact on printing!
