Results 1 to 16 of 16
Thread: Digital Signatures
    Workshop Member Reynolds's Avatar
    Arlington, VA
    206
    24
    Smile Digital Signatures
    How do you add a digital signature to an image instead of actually signing it with a Sharpie or the like? Jack, you are adding a facsimile of your signature. Share yet another secret!!!
    Best,
    Reynolds
    Best to all,
    Reynolds
    Maggie O's Avatar
    Standards Are Down All Over
    3,064
    Re: Digital Signatures
    A scanner, a sheet of clear plastic, a Sharpie and Photoshop layers.
    Los Altos, CA
    10,486
    1031
    Hi Reynolds!
    You mean an actual signature like I did in the lower left corner of the one below, or having a digital copyright embedded?
    home: www.getdpi.com
    Arlington, VA
    206
    24
    The actual signature as you are showing in your example image. I was thinking about adding mine to some now that I am so much the better photographer thanks to you!!!
    R
    Best to all,
    Reynolds
    Los Altos, CA
    10,486
    1031
    It's actually pretty easy. Here is an excerpt from an article I wrote a while back:
    The first step is to create a “Signature” brush is PS. You can scan in a handwritten signature or use a font you like. Here is how to do it:
    1. Open PS and create a new file about 500x500 pixels. Make sure the background is set to “transparent” or "white" and while not critical, I use sRGB color space and 8-bit mode.
    2. Select the “Type” tool and drag a box onto the transparent background. Select a type style you like and type your signature in black as you want it to appear on your images.
    3. NOTE: I add the copyright symbol to the left of my name. To get the copyright symbol in windows, hold the “alt” key and type “0169” then release the alt key; on Mac, it's Option+G.
    4. Once you have the signature the way you want it, merge the layers.
    5. Now using the rectangular marquis, outline the signature area.
    6. With the selection active, go to Edit/Define Brush Preset and give your brush a name you will recognize like “My Signature” and click “okay”. Your brush is now saved and is the very last brush in the brush palette dropdown list, but it is likely not the best size for your uses.
    7. To correct the size you can now adjust it like any other brush, but the font can go fuzzy, so it's usually best to make a few brushes of different size brushes by re-sizing your font in step 2. I find 250 pixels to be a good standard size for prints, more like 30 for web. Simply size your brush to the new standard size you want a re-save it so you wont have to redo this step each time you use it.
    8. For an actual signature replica, in lieu of step 2 above scan a copy of your signature, preferably black ink on white paper since you will be selecting the signature only for use as your brush. Select the signature with the magic wand tool and paste it into the transparent background. Proceed with steps 3 through 6.
    Now that the brush is made, you can simply stamp it on an image, but with layers we can be far more creative. For example, I like to first select a complimentary color from my image for the signature itself. Then I like to place it on a layer above the final image that is slightly transparent with a drop-shadow – this gives the effect of the signature being done in a colored bead of water over the image.
    BTW, I'll demo this in Moab
    Arlington, VA
    206
    24
    Looks like I am going to need some lessons on the "Select the signature with the magic wand tool" part. If I am using the right tool ("Quick Select" in CS3), I am having a tough time getting it confined to just the signature scanned. Wish I could make Moab!!
    Best to all,
    Reynolds
    Los Altos, CA
    10,486
    1031
    Reynolds:
    Re-read instruction #5 --- I say use the "RECTANGULAR MARQUIS" tool, NOT the magic wand or quick-select! The marquis tool is the square (or oval) dotted line at the top of your menu bar and you can use either square or round, doesn't matter. Just need to select around the signature to include it all in the brush you make.
    Subscriber Member TRSmith's Avatar
    Central Maine, U.S.A.
    2,406
    9
    If you're attempting to select your black signature from the scan, try using the "magic wand" and not the "quick select". If you click and hold the Quick Select you'll see the old magic wand as an alternate option for that tool. Now select the white of the background and then inverse the selection. That's it (roughly) but you may have to clean it up a bit depending on the tolerances of your Magic Wand.
    Los Altos, CA
    10,486
    1031
    Quote Originally Posted by TRSmith View Post
    Another option is to hit the levels sliders hard to make the background more pure white, then the brush creation will ignore it when building the brush
    Arlington, VA
    206
    24
    Yes, I am trying to use the actual signature. I did find the magic wand. Now, I just have to learn how to use it! Sorry to get you guys involved in this relative madness!!
    Now, that I have the wand, I will figure it out. I can get parts of the signature to copy, just not the whole thing as it is.
    Many thanks for your help here. Has nothing to do with the art of photography. Literally, "form over substance"!!!
    R
    Best to all,
    Reynolds
    2,406
    9
    After you apply Jack's levels suggestion, click the white area of your scan. It should select an area of white that runs into the black of your sig. To select all the white, rather than click inside each vowel, etc., go to the "Select" pull-down menu and click "Select Similar". It should select all the white pixels on your black and white scan.
    Los Altos, CA
    10,486
    1031
    Reynolds:
    If you get stuck, email me the scan and I'll create the brush for you and email it back to you.
    Arlington, VA
    206
    24
    You guys are very patient! Guess who took the attached image at Yosemite!
    Many thanks!!
    Reynolds
    Best to all,
    Reynolds
    Los Altos, CA
    10,486
    1031
    Congrats Reynolds!
    2,406
    9
    Nicely done!
    Senior Member Lars's Avatar
    Sunnyvale, California
    1,811
    19
    Just a thought on security...
    Perhaps it would be a good idea not to publish your handwritten signature on the internet. Or make sure the signature is quite different from the one you use in legal matters.
    Lars
