Results 1 to 2 of 2
Thread: Sheet feeder only on 3800 on 10.8.5
    Apr 2009
    Sydney, Australia
    581
    2
    I am running a 3800 on Lion 10.8.5 and having skew problems with Museo cards. I wanted to try using the front feeder but the paper source is Sheet Feeder with no option to select front or rear feeder.
    I'm baffled. I've installed the latest driver, deleted and recreated the printer, and rebooted but it doesn't changed.
    Anyone else had this problem?
    Jeff
    www.jeff-grant.com
    Apr 2009
    Sydney, Australia
    581
    2
    Re: Sheet feeder only on 3800 on 10.8.5
    Just solved my own problem, I need to set up the source in the paper definition. Now, if my skewing problem was that easy.
    Jeff
    www.jeff-grant.com
