Results 1 to 3 of 3
Thread: Trouble Loading Paper Profiles
    Subscriber & Workshop Member
    New York, NY
    1,178
    414
    I have samples of three papers from Monoprint: Rochester, Rochester Plus, and Rochester Warmton. I have downloaded the ICC profiles from the Monochrom website here:
    http://monochrom.com/cc/monoc/shop/m...&text=20407599
    I have placed them in the correct folder Windows>System32>spool>drivers>color - But they do not show up in the CS3 Print Dialog Box in the Printer Profile drop-down list.
    I have also added some other profiles (at the same time) and these show up and work fine so I am pretty sure I have them in the right place.
    The files only show up as 1KB when I place them in the directory.
    I am on a PC, CS3.
    Can someone try to download them and see if they show up for you. Any other thoughts would appreciated as well.
    Los Altos, CA
    10,486
    1031
    Re: Trouble Loading Paper Profiles
    Hi Charles:
    If a profile is sent to a PC from a Mac, there are actually TWO files sent, one is large and the other is small, usually a .icm instead of .icc and usually 1KB. You need to ignore the 1KB files and only load the larger ones on your PC. You are using the correct location.
    home: www.getdpi.com
    Subscriber robsteve's Avatar
    1,202
    496
    On a PC you can also right click the profile file and choose install.
